Red Zeppelin Build
@yArdbird Here's some photos of the bypass relay installed in the passenger kick panel cavity.
Relay harness wiring pinout:
  • Black and blue wires go to chassis ground via a ring terminal.
  • Red wire goes to the Parking Brake switch wire on the factory PTO harness (white wire with blue tracer) via a Wago 221 connector.
  • White wire goes to the white with orange tracer passthrough wire, which is tied to the Upfitter relay #1 wire under the hood via non-insulated splices and adhesive lined heatshrink tubing.
Awesome! And thank you.
I’ll have to crawl around the truck and make sure everything makes sense. All of this was done in the passenger footwell where the BD high idle plugs in correct? With this done, your high idle will either work when you set the parking brake if when you flip upfitter 1 on without the parking brake correct?
This is definitely on my future mods list.
Correct! There is also a small amount of work to do under the hood where the Upfitter and passthrough wires are (only splicing two wires together).
Lube shuttle Li400 greasing kit finally came today and got all the red factory grease out of the front U joints. That was a mess to clean up!
Since this grease lasts alot longer, I will regrease on the 2nd or 3rd oil change. My first oil change should be within two months.
Got my OEM cup holder ambient light installed! :D
Hardest things were fishing the wire harness and removing the console.
Just showing the light ring installed; will take a pic of them working this evening!
One of my favorite mods.
I added one more Bosch relay in series with the BD high idle knob's yellow wire. Now I can just trigger it and the parking brake override at the same time from Upfitter #1 without having to cycle the BD high idle knob on and off. :D
interested in more detail please? also, would it have been better to just use a resister and have the system all tucked in that passenger foot well? I'm debating all of my options. Thank you in advance!
A resistor doesn’t allow you to vary the RPM on the fly. The BD diesel knob does.
Got the OEM unpainted mirror caps and Boost Auto Parts smoked mirror signal indicators/spotlights installed. @Vecman Looks much better now than stock with the chocolate dipped mirror caps. :cool: :D
