Red Zeppelin Build
Installed the Limitless mirror spotlight override today. Detailed pics in order below.
@BroncoHooves I will poke around today, see what I can find, and report back...
@BroncoHooves this is new territory for me but I see two memory addresses for enabling "Manual Regen" in the IPC module. Did you change one or both of these?
720-05-02 x*xx xx--
720-07-02 x*xx xx--
I do not see anything for a chime associated with this, but there are two addresses for "DEF Warnings (DEFW)" in IPC:
720-05-01 xxxx xx** xx--
720-07-02 xx*x xx--
Example: Looking at the As-Built from a Diesel Superduty:
720-05-01 0000 0110 003E
720-05-02 0000 002E
720-07-02 0742 48C1
"10" would become "00" (10 = DEF Text/DEF Telltale, 0 = Disabled)
"0" would become "4" (0 = MR Disabled, 4 = MR Enabled)
"7" would become "F" (7 = MR Disabled, F = MR Enabled)
"4" would become "0" (4 = DEFW enabled, 0 = Disabled)
You could try the third character in the 720-07-02 address, but it doesn't sound to be exactly what you are looking for...
Another option... there is a generic "Chime Generator (CG)" in IPC. The options are:
CG audio, single (using the audio system?)
CG cluster only (using a separate dash speaker?)
CG not used (turned off?)
I think this would impact all chimes, which may or may not be a good thing...
720-01-01 xxxx xxx* xx--
Example:
720-01-01 2F0F 1064 704B
"4" would become "0" (for CG cluster only) or "6" (for CG not used)
I'll look a bit more, but I think the latter solution may be worth a shot. Let me know if you have questions.
720-05-02 x*xx xx--
720-07-02 x*xx xx--
720-07-02 xx*x xx--
720-05-02 0000 002E
720-07-02 0742 48C1
Example:
To enable OCR, you have to do two things in the plain english mode in IPC and PCM: https://www.ford-trucks.com/forums/...d-on-operator-commanded-regen-in-forscan.html
However, when you uncheck the Auto Regen box, when you start the truck you'll get a warning in the instrument cluster that you must dismiss with the OK button (and the chime) so it's kindof annoying, since I already dechimed my truck with other Forscan settings :)
Doesn't the turn signal sound come from the same chime generator? I don't want to lose that sound. @Modman
That would be the downside, I don't think you would get ANY chimes if you changed it to "not used". The turn signals do have a different sound, though, so it makes me wonder if those would be impacted...
Painting my front hubs black at the moment; first coat of primer down. :)
Bronco. So to remove all that is needed is the removal of the 3 screws? What position do they need to be in prior to removing.
Yep, it was super easy with a T27 torx bit and an impact driver. Removing the hub caps was easy as well with the factory lug wrench in back seat.
Mine were in the unlocked (Auto) position before I removed them.
So don't have to worry about springs or parts popping out like a jack in the box? Showing my age now.
Nope :) I pulled the hubs out easily with just my fingers grabbing the unlock knob and wiggling.
I cut a hole in some cardboard and pushed the hubs through it to keep the splines from getting paint on them.
@Lunch Box
Painting my front hubs black at the moment; first coat of primer down. :) Prepped the original finish with some Scotch brite first.
This is exactly what I had planned. Can’t wait to see them done!
Looking forward to the finished product. Also please get a picture before reataching hub cap. I don't run them. Thank you!
Will definitely get some pics tomorrow without and with hub cap.
I did 2 coats of primer and 2 coats of the satin black. Will get them installed in the morning before I head out.
