Red Zeppelin Build
It's in my post history ;) Make you work for it lol
How much are you paying? Because I could be convinced to work for money given how many posts you have. ;)
I was looking at the BD diesel adjustable high idle module instead of doing just the single resistor mod on an upfitter, but it seems the vehicle has to have the parking brake applied to take advantage of it.
Not sure if there's a workaround solution for when I just want to remote start it and not wonder if I engaged the parking brake previously.
I did 12 volt solutions high idle. Same thing, requires emergency brake. I’m still putting myself in the habit of doing that, but I felt like it wasn’t a big deal to learn/remember. I didn’t want an upfitter switch, resistor install, or the BD dial
Does the high idle mod prevent the engine idle hours from accumulating/racking up in the cluster?
No clue. I do know it took all of 30 seconds to plug in down in the passenger side footwell. But I don’t know if it effects the accumulation. I should have it back from the shop today or tomorrow (suspension). Tell me how to check what you want to know and I’ll test
This guy said that high idle does in fact count towards idle hours. Case closed I guess!
So you’re looking to idle your truck without the computer knowing you’re idling your truck?
Nope. Would be a bonus is all. What RPM setting did you choose?
1400 - had the option of 1200, 1400, or 1700. I don't live in a cold climate, but since it's a one time choice, felt better about going with the 1400. If I ever decided to live somewhere I would need 1700, then I've made some terrible life choices! Haha
I saw a pretty red tremor this morning around Leander on my way home from work. I wondered if it belonged to someone here. Were you in the Leander area this morning in the fog?
Wasn't me :(
Self contained ratchet straps came today in addition to the Element50 fire extinguisher.
Good Man!
I've never seen anyone else choose the solid state extinguishers!!! They are fantastic - I sacrificed one to a test, and it performed much better than I had anticipated. I mounted mine directly under the front seat - directly behind my feet. And you?
Good Man!
It's in center console :)
I installed the BD switch and have been very pleased with it. Install was probably 15 minutes with most of the time spent finding a coat hanger to help fish the wire from the passenger to driver footwell. You do have to set the parking break but ever since I’ve driven a standard transmission I’ve been in the habit of setting it so not a big deal for me.
Pro, it doesn’t use an upfitter.
Con, requires the parking break so I won’t be able to use it when winching.
Thank you for the review, I think you've almost sold me. Would you say the variable pot/knob is worth it, or not, to have a bunch of RPM ranges? @yArdbird
As far as I know, all of the high idle kits available on the market require the parking brake to be set. There's a post on FTE forum on how to fix this though.
New Truxedo cover has wrinkling/bubble waves along the edges. For the earlier issue (same cover), they're wanting me to try cleaning off the white marks with their recommendation of CocaCola tomorrow and report back to them..
CocaCola? The soft drink sold in groceries stores? That's...interesting.
And seriously, you are getting one heck of a lot of problems with this cover.
