Red Zeppelin Build
CocaCola? The soft drink sold in groceries stores? That's...interesting.
And seriously, you are getting one heck of a lot of problems with this cover.
Yep! Dawn soap and water and a toothbrush (their first recommendation) didn't work. This is really the only cover that fit my versatility requirements as well.
And alot of covers... Is this number #3 or a new issue with #2??
Disregard, I see that you stated it was the same cover...
Yes, same with me... I'm hoping things get sorted out for you.
CocaCola didn't work. Imagine that. :rolleyes: It's woven fabric that absorbed whatever ink they use.
Thank you for the review, I think you've almost sold me. Would you say the variable pot/knob is worth it, or not, to have a bunch of RPM ranges? @yArdbird
As far as I know, all of the high idle kits available on the market require the parking brake to be set. There's a post on FTE forum on how to fix this though.
I think it’s worth it. Again it doesn’t require use of an upfitter switch and it gives me flexibility in the RPMs when idling. I’m in FL so I don’t see the cold temps others do, but I try not to put the truck into gear until my oil temp is 100. When it is cool I turn the knob and adjust my idle to anywhere between 900-1200 to speed up the warm up. Where I hunt it tends to get colder so I might increase it in those situations, but in the range I mentioned it’s usually not more than 5 minutes of warmup.
I've got the same color truck. Did you go for Gloss or Matte (hard to tell)? Clear overlay vs. individual letters?
First post of this thread has all the details.
Black with clear overlay (for OEM look)
Truxedo confirmed today their employee(s) used the wrong fabric marking chalk (ink).
Glad they figured out what happened and owned up to it. Sucks that it happened, though.
Yes but not for awhile. Really telling about how much they care.
Just want to say I installed a Truxedo fabric cover about 4 months ago. It was absolutely perfect with fit and finish. I love the matte fabric over the vinyl, no issues with delamation. Cleans up very easily. Its disappointing Bronco is having the issues he is having. I truly believe the current workforce in this up side down world we are living is the, or part of the cause. I also believe it is responsible for most of the QC issues coming from Ford. No one seems to take pride in the work they do, I will correct myself, there seems to be a large number who don't. This forum is great and I believe it will help keep some manufacturers accountable.
@soop Mentioned a couple months ago how bad my fender/hood body gaps were on the front of the truck when I got it. I tried to fix them a few minutes ago with a 10mm socket, and this is the best I can do without messing around with the hood. The driver side fender was installed too far aft at the factory and unfortunately it's seam sealed. @soop
