LED Bumper Light Bar / Flag Mount
Let me first say thank you for posting this. That is the cleanest light bar install I've seen yet and I'm absolutely going to copy it!
Next, I'm a 20 years Silver Lake veteran. I think I've had a dozen of my vehicles up there now. See ya this summer!
Thanks @SVT4X4 for the inspiration to tackle this project.
Finished up my light project today - Rigid light bar and BD fog lights. Definitely some lessons learned along the way and here are my tips if you want to give this a go. Super happy to have a decent set of lights now.
Disassembly
  • There are two electrical connections to the bumper on the 6.7 - fog lights AND block heater plug. Forgot about the heater and it was painful to get that off mid flight while holding the bumper.
  • Take off all extra brackets behind bumper. You cant get to the fog or the main light bar space very easy and it makes it much easier to work with those off.
  • All plastic must be removed. Most are pretty standard clips. The top of bumper pad can probably be taken off without breaking the clips, but once I broke two on mine, I just gave in to buying a new one. All three pads from the parts dept will run you about $80.
Cutting
  • This part is not for the weak stomach folks. You will scratch your bumper even with masking tape. The good news is that rattle can bed liner works great in covering up the scratches and since the light bar portion is not next to anything shiny, it will be ok.
  • For both marking a straight line and the actual cutting, you are working on two radius edges - horizontal and vertical and so there are challenges there.
  • Tried string and several other straight edges to mark my cutting lines, but found a 100ft metal tape was most flexible and gave the best straight line.
  • Drill holes in each corner. Use a 4.5 inch cutoff wheel. Easier than it looks to keep a straight line with that big of a wheel.
  • Be careful on the initial cut as that's where my wheel wanted to slip the most.
Mounting
  • The Rigid RDS-SR light fits perfectly in the space. Instead of welding mounts, I was able to use the factory mounts and drilled a hole in the top of the bumper for the mounting bolt.
  • My light is a 30 inch, but think a 40 could work as well.
  • Wiring was straight forward to the upfitter wire location.
View attachment 9467View attachment 9468
View attachment 9471View attachment 9464View attachment 9469View attachment 9470
You guys knocked it out of the park!
I had been debating on what to do on my front bumper for a dune flag mount and was going to build it into a light bar mount. With this did not want to block any airflow going into the truck, and was first going to put the light bar in front of the main bumper bar, but it looked like it would partly block the front camera. So ended up cutting a piece out of the bumper, getting a curved light and installing in the bumper welding some light mounts on the inside. Then used a rattle can spray bed liner on that part of bumper. Really like how it turned out. Then for a flag mount made a two piece that bolts to the bumper bolts, and I can remove the outer piece if needed. View attachment 6900View attachment 6901View attachment 6902
CLEANEST LIGHT BAR SETUP EVER!!!!
Would this work with the winch?
Do you happen to know why? is it is the mounting bracket for the light bar? If so, maybe the bracket can be welded. Just trying to understand if it is physically possible or just difficult.
I do not -- it was my mechanic who told me there was no room once he removed the bumper to inspect.
I installed the OEM Ford/Warn winch this weekend and it sure looks like there is room above the winch. I plan to give this mod a shot! now I just need to pick the light!
Sweet!! Let us know how it works out. I’m highly interested in adding a front light bar myself! 💡
Any updates about winch and light at fitting in bumper together?
I never saw this thread until now - damn that's a clean mod! By adding the light bar like that it looks absolutely factory! I am not sure I have the guts for this mod - but I want to do it! I do have the winch, so I would be interested to see if it ends up fitting. I love the idea of my truck being silver with this mod - may be able to pull it off where it appears hidden - unless I need tp paint it black or use bed liner as shown here.
X2 on just discovering this thread. And I too would have to work around the winch. There's coming a time very soon when I'm going to have the time for what I would consider major mods to take on this project. Probably later this summer, but that kind of stuff is going to be my full time job in retirement. Looking forward to getting my shop up and running and digging into the truck in earnest .
As other's have stated this has got to be one of the cleanest and most factory looking light mods ever done. And yes because a new person dug up the thread I just discovered it. Definitely on my mod list. And yes I like it so much I comment twice! :LOL: 🍻
I saw this on a local Tremor (Arizona) back in late 2020, prior to having my Tremor or even having it on order (July 2021) and it was on my buckets list of mods.
When I picked up my Tremor and started actually playing with my mod list, it was quickly determined this was not possible on Tremors with the factory front bumper winch. The winch did not allow room to slip this light bar in there so I mounted it on the bottom of the bumper.
