LED Bumper Light Bar / Flag Mount
SVT4X4 where did you purchase this item and is it a curved light?
I used this one from Amazon, just search description.
CREE LED Light Bar 36inch Curved 180W Single Row Spot Flood Combo 3D LED Driving Fog Lamp Off Road Lighting LED Work Lights for UTE ATV UTV SUV Boat Jeep Trucks IP68 Waterproof (180W)
Thanks @SVT4X4 for the inspiration to tackle this project.
Finished up my light project today - Rigid light bar and BD fog lights. Definitely some lessons learned along the way and here are my tips if you want to give this a go. Super happy to have a decent set of lights now.
Disassembly
  • There are two electrical connections to the bumper on the 6.7 - fog lights AND block heater plug. Forgot about the heater and it was painful to get that off mid flight while holding the bumper.
  • Take off all extra brackets behind bumper. You cant get to the fog or the main light bar space very easy and it makes it much easier to work with those off.
  • All plastic must be removed. Most are pretty standard clips. The top of bumper pad can probably be taken off without breaking the clips, but once I broke two on mine, I just gave in to buying a new one. All three pads from the parts dept will run you about $80.
Cutting
  • This part is not for the weak stomach folks. You will scratch your bumper even with masking tape. The good news is that rattle can bed liner works great in covering up the scratches and since the light bar portion is not next to anything shiny, it will be ok.
  • For both marking a straight line and the actual cutting, you are working on two radius edges - horizontal and vertical and so there are challenges there.
  • Tried string and several other straight edges to mark my cutting lines, but found a 100ft metal tape was most flexible and gave the best straight line.
  • Drill holes in each corner. Use a 4.5 inch cutoff wheel. Easier than it looks to keep a straight line with that big of a wheel.
  • Be careful on the initial cut as that's where my wheel wanted to slip the most.
Mounting
  • The Rigid RDS-SR light fits perfectly in the space. Instead of welding mounts, I was able to use the factory mounts and drilled a hole in the top of the bumper for the mounting bolt.
  • My light is a 30 inch, but think a 40 could work as well.
  • Wiring was straight forward to the upfitter wire location.
View attachment 9467View attachment 9468
View attachment 9471View attachment 9464View attachment 9469View attachment 9470
Great job, looks amazing.
Disassembly
Cutting
Mounting
I hate this forum!! But I love this Forum!! The cool ideas that is share here alway makes me sad ? But also makes me ? happy. Bottom line I look forward to doing the same project on my truck but It’s going to cost ?. But Hell, you can’t taken with you, right! Damm good work!!! When I do my truck, I will record it post it. I‘m going to 1st upgrade the Engine By adding super charge, air intake and whole catback system. After that project is done then i will Tackle this upgrade. Thanks again for Sharing.
Disassembly
Cutting
Mounting
Nice job!
Disassembly
Cutting
Mounting
hey i have a 2021 Tremor and i want a light bar how you did yours or 2 in the grill. how exactly did you cut that slot for the light bar
Disassembly
Cutting
Mounting
This looks FREAKING amazing!!! I can see it looks good in photos, but how close did the BD fog light housings match to the Agate Black? Want to order these but will either wrap or powder/paint them to match if it doesn’t look close enough. Let me know!!!
The bumper is gloss in the fog area and so are the light fixtures. Pretty close but it’s tough to match perfectly against factory paint with ceramic.
Has anyone determined if this will work with a winch set up? I'm looking to get this done or do I have to mount it to the top of the bumper?
