They are Feniex Emergency Lights. I have them in Amber/White and they work in Flood also.What lights did you mount behind the grill?
How are they mounted back there?They are Feniex Emergency Lights. I have them in Amber/White and they work in Flood also.
I have those on order as well. Was install a pain?I am interested in that product.
Do you have pics of them in action?
I have the limitless strobe on the entire truck but with having all white LEDs, I am wanting to introduce some amber lighting in the mix.
This is from my 2019 but I did the same setup I have in my 22.How are they mounted back there?
That’s what I was afraid of. I have the kits for all the lights, i really don’t want to have to link them all up to sync together. Who did the install and do you mind telling me the cost?Yes.
A shop did the install for me but it can get very tideous due to the amount of relays each light contains if you decide to strobe every light.
Thanks!This is from my 2019 but I did the same setup I have in my 22.
I used the "L" Shaped bracket in the link below.
What shop?If I recall correctly, I think it was 10-12 hours of shop time.
What shop?
I did the install myself and it was pretty simple. The fronts in the grill are the fusions but all the rest are quads. I did all my lights on here.Wiring looks simple.
These are the Fusion lights?
Thanks for the link - just more stuff I want to add. Sigh
I’ll do a video and post up this evening.I am interested in that product.
How did you attach the lights on the running boards?
with the way these lights are mounted do you think the regular light bars will work as well here than the one you have mounted on the front? I don't need emergency lights like this but I've been trying to figure out a more cleaner way than the surface mounted lights or cutting the big hole in the bumper like the OP since my bumper is chrome.This is from my 2019 but I did the same setup I have in my 22.
If you go with the single row 10" bar it would work fine behind the grill on each side of the center bar. I had test fitted one on my 2019.with the way these lights are mounted do you think the regular light bars will work as well here than the one you have mounted on the front? I don't need emergency lights like this but I've been trying to figure out a more cleaner way than the surface mounted lights or cutting the big hole in the bumper like the OP since my bumper is chrome.
Ok thanks. Is 10” the only size that would fit there?If you go with the single row 10" bar it would work fine behind the grill on each side of the center bar. I had test fitted one on my 2019.
If this is where you want to mount it, the 10" is the biggest that will fit in that spot. Let me know if you were thinking of another location. Just so I didn't misunderstand.Ok thanks. Is 10” the only size that would fit there?
