Featured
- #1,001
I tried the o-ring removal and still had vacuum release when removing the Def cap. Reinstalled the o-ring and drilled the cap…no more vacuum.
Except you can’t see every angle of the tankI don't think the DEF guage is accurate enough to use as an indicator of decreased tank capacity - it's easy enough to stick your head under the bed and take a look at the tank - it's right behind the fuel tank.
Gas?I just put 30 gallons of gas in my car, have the Tank Wardens, and the check engine light turned on... any suggestions?
If they put gas, the least of their problems is the Tank WardenGas? Tank Warden is only for diesel vehicles.
As for the CEL, pull codes - likely not related to fuel system
I have them on my truck and they work greatIf they put gas, the least of their problems is the Tank Warden![]()
Did you install the Tank Wardens recently?I just put 30 gallons of gas in my car, have the Tank Wardens, and the check engine light turned on... any suggestions?
Just saw the comments related to DEF tank vacuum and read through them all. I have one of the first batches with the black plastic and no vent tube within the zip tie hole (I checked with a fine wire and it was completely smooth). I haven’t noticed any vacuum or air hissing but decided to drill an opening anyways. Slightly annoyed because it’s a bit off center
As did I for the exact same reason.I recently did the same thing for the same reason. Ran 10ks of miles without issues or even vacuum sounds when removing the cap. Still, I saw the thread and drilled a hole. Off center. Ugh.
I meant diesel.Gas?
I wish I had a code reader, I guess I have to wait till Monday for them to check it out at the dealership. (I didn't do anything with the DEF that day)Did you install the Tank Wardens recently?
If you don't have a code reader handy, it's easy enough to slowly back the fuel cap off and listen closely for a hissing sound. I know the vents on some of the Tank Warden DEF caps needed to be drilled due to extra material from the printing process clogging them. I'd imagine it's possible for the fuel cap to have the same issue.
Autozone has a free code reader, also what does the ford pass app say?I wish I had a code reader, I guess I have to wait till Monday for them to check it out at the dealership. (I didn't do anything with the DEF that day)
Also to note... My truck went through a regen process in the morning, so it could be in that system
There's several on Amazon that you can get immediately and inexpensive:I wish I had a code reader, I guess I have to wait till Monday for them to check it out at the dealership. (I didn't do anything with the DEF that day)
The rubber gasket ring broke on mine, anyone know what size or where to buy another?
No @Optimus🤖 not that kind of rubber ring![]()
