DTX2023Tremor's Money Pit Build and other miscellaneous topics
Thanks and great to hear from you! I have a few more mods planned, and it will be another year or two before I'm done. I've got a few expensive hobbies and the truck definitely tops the list as of late. Fortunately, my wife likes the truck and is really supportive of the mods. She always asks me what I'm doing to "her truck" when I get the next thing ordered.
I thought you have a travel trailer and plans for some trips. Were those relatively local trips? Join the meet-up at Big Bend in November....it's only 1,500 miles each way 😉
We actually have 3 that are traveling that far or futher!!
We do a the new 5th wheel. Longest trip we took with it this year was about 200 miles one way. Fairly local. Hoping to venture out next year for a few longer ones. Wifey wanted to keep it local for the first year to get the hang of things before we got to far away from home.
I'd love to come down for the meet-up but I have a hunting trip planned at the same time.
Today started out to be one full of optimism. I was going to service the differentials, transfer case and replace my factory transmission pan with the SPE pan. Sadly, I don't think the SPE pan will work for the 23+ gas engines. Ford wraps the transmission cooling lines really close to the pan, which negates how SPE approached adding capacity. The SPE pan isnt tapered like the OEM pan is, adding 2" if width and about 1/2" in depth. The cooling lines look like they can accommodate the slight added depth, but I'm doubtful that the width would be possible. I'm also concerned that the way the driver side cat is positioned may also be an issue. Didn't want to go through all the trouble to drop the transmission pan to only have it not work.
I've reached out to SPE to see if they have another customer with a 23+ gas engine that has successfully installed the pan.
Yeah, I purchased on x-plan... not the best deal out there, but definitely a good price.
Roughly how much was the discount? Thinking of going over there this weekend and seeing what they can do on the leftover '24s they have. Anyone specific you recommend I work with?
Thanks in advance!
Roughly how much was the discount? Thinking over going over there this weekend and seeing what they can do on the leftover '24s they have. Anyone specific you recommend I work with?
Thanks in advance!
Ford Partner Recognition (X-Plan) Pricing is a special pre-determined price, which is based on the following: Ford Employee (A-Plan) price plus 4% plus $150. If you have x-plan, it is likely the best deal you're going to get unless you go through a place like Granger Ford in Granger, IA who is offering 2% (sometimes above, other times below invoice). When factoring the cost to get to Granger, IA and back from DFW, x-plan locally is a better deal.
My MSRP was $85,310 and my x-plan price was $81,012 - saved about $4,300 off of MSRP.
My sales rep there was Aaron - he was really easy to work with and didn't try to push anything. Different story when you get with the finance department. It helped that I had a cashiers check already cut so it took a bit of the wind out of their sales.
Nice! Thanks for the info!
Well...looks like Aaron has moved on to greener pastures...
See if Justin Lines is still there. He is the sales manager.
Anti-Matter Blue is an awesome color (I am a bit biased though). Platinum trim?
Yes sir! Also went from gas to the 6.7 HO. A steep learning curve as this is my first diesel. They are going to come grab it, hopefully some time this week, to do the bed liner.
Over the last week and a half, I’ve had my truck at Renegade Customs in Rockwall, TX getting a few mods knocked off my list. Shout out to Will at the shop who has taken such great care of my ride.
First up was the train horn installation. I decided to go with the Motohorn 3.0 dual horn kit. This doesn’t sound like the typical train horn that you might get from Horn Blasters or Kleinn as the trumpets are identical so you don’t get the different tones to create the harmonic train horn sound. That said, these are really loud horns. Likely not as loud as the other brands, but for a huge fraction of the price and not needing to install a compressor, tank and run airlines, this was the right solution for me.
The horns are connected to upfitter switch #1 via the 2023-Present Super Duty Train Horn Integration Harness. It may be helpful to know that if you are planning to go the same route as I did, you will need to have a harness for each horn as they are individual units. Will at Renegade was able to find a way to splice it into the factory horn wire in a way that allowed me to get away with only having using one harness.
Up next was installing the MXT575 MicroMobile®Two-Way Radio from the June (?) group buy. Thanks again to @legmar for getting us such a great deal on the radios. I had initially purchased this with the following parts:
I also purchased a CB/ HAM Antenna extension bracket which will allow for the antenna to be installed on the ditch light mount. I had considered the third brake light antenna mount, but decided against that as there’s a couple of garages that I take my truck into that I’m already pretty close to clearance height and didn’t want to add anything that could possibly get knocked off (especially as I add a little height going up to 37” tires in the future).
As Will got into the install, it turned out that I needed a bit more length on the mic cable so purchased an extension on Amazon: CAT6 8-Pin 1.5 Meter / 59 inch RJ45 Mobile Radio Removable Separation Microphone Speaker Mic Extension Cable Cord for Kenwood ICOM TM-V71A IC-2730A.
For the interior portions of the install, I went with the following:
The Midland was then wired-up to upfitter #2 and the WeBoost moved to upfitter #3, leaving upfitters 4 – 6 available.
Well done and well documented! Gonna be fun!! 🤩
The most significant mod that was done this past week was lighting. I had the following installed:
The ditch lights were installed on SDHQ '23-24 FORD SUPER DUTY SDHQ BUILT A-PILLAR LIGHT MOUNTS with the BAM swivel mounts with the Single-Bolt Mounting Adaptor added in (another thanks to @legmar for the great idea). The S1 was mounted to the side of the XL80.
All of this was wired to a Switch-Pros SP9100. The Switch-Pros control unit was mounted onto the side of the battery tray while the switches themselves was mounted to the SwarfWorks Switch-Pros SP-9100 Mount which replaces the sunglass holder. The cable that comes with the Switch-Pros was too short, so had to order 20' communication cable to connect the switches to the control unit.
I was initially going to install an OnX6 Arc LED Light Bar above the front bumper and had even purchased 2020-2022 F250/350/450 40" Baja Designs Onx6 Radius Light Bar Mount brackets from KD Fabworks. Turns out the bumper for the 2023s is different enough that the KD Fabworks brackets wouldn’t work, so that changed the entire plan as the only other option was to go with a bumper bar mount which isn’t something that I am interested in, so had to pivot to the 7XL Linkable kit.
As you can imagine any shop doing an install is going to prefer using their vendors for parts. I get it, they’ve gotta keep the lights on and my shop is generally willing to work with parts they don’t typically sell. In this case, they have their own supplier for Baja Design lights so when we made the 11th hour pivot form the OnX6 to the 7XL Linkable it became a bit of a scramble to find the 2023+ kit. Their vendor was out of stock and so I reached out to Baja Designs, speaking with a salesperson there who told me they were also out of stock and it would be built to order, resulting in a 2 – 3 week lead time. I wasn’t too crazy about having to bring my truck back in a few weeks for the install, so now was left with trying to find an alternative.
This was a good lesson for me to think of forum vendors first. Huge shoutout to @Nick@ApolloOff-Road who really came through for me. I reached out through the normal chat on the Apollo Offroad website and was initially told that they too were out of stock (this was late afternoon on a Friday). Well, I guess Nick must not take days off as first thing Saturday morning he reaches out to me (while out of town for a wedding) to let me know that he has them in stock and will get it shipped to my shop on Monday. I needed it sent overnight as didn’t want to lose days in the shop with ground shipping and he took care of it. He didn’t know until afterwards that I’m a forum member so this must be the typical service-level that anyone who shops with Apollo Offroad must receive. I’m impressed. Thank you Nick for taking such good care of me.
The last mod for this round was adding the Carli 23-24 FORD F250/350 4X4 LOW MOUNT STEERING STABILIZER WITH DIFFERENTIAL GUARD. The issue with just having the upper steering stabilizer is that it adds resistance in one direction, and steering is softer in the other. Adding the lower one balances it out as well as gives the truck a bit of bias to driving straight ahead, making it track a bit better and requiring a little less steering input on straight roads.
