Did fuel filters now no start
AZ I think so, I don’t think I installed the lower filter correctly the first time, and I didn’t really know what to listen for during priming. After hearing it catch fluid and act like it should now it never did that yesterday at all so I’m thinking something about the first lower wasn’t right and then I ‘primed’ it only it didn’t prime and then I did the under hood filter and tried to prime again and by that time I had air all over the place. I think putting some diesel in the return line and taking the fill cap off combined with being able to see the back side of the filter cover and giving the two back screws a little extra tightening came together and solved my issue.
Aaron you aren’t even close to the first guy that suggested starting fluid, maybe on here yes but out here that was everyone’s first suggestion. Even the mechanic that works on our huge v12 and bigger natural gas compressors told me to hit it with some, I responded I don’t have any and he came back with ‘well you got brake clean, your truck won’t know the difference’🤦🏻‍♂️ needless to say i understand why we have so many compressor issues lol
It'll work haha... but the key point is the closed system wasn't closed 🤷 lol. Like a cigarette with a hole in the filter you're not going to draw anything from that cancer stick that satisfies!
Glad you got it worked out regardless! Maybe throw some additive into the tank that has dewatering like Archoil 👍 any residual air mixed in can bring on H2O just from the breakdown process in the fuel system. Check/drain 2oz or so next month from the separator. Wouldn't hurt! Cheers 🍻
Back in the day we made sure ETHER was the LAST THING to ever do when starting. Some trucks would NEVER start without it after using it once. We would label them "ETHER Bunnies"....
STAY AWAY from ether if you don't want more problems than it solves.
Glad the priming got worked out. 😎 😎 🇺🇲 🇺🇲 🇺🇲 🇺🇲
About the ether/starting fluid suggestion from what I understand, here's what would probably happen hitting a fuel-starved 6.7 with ether:
The CP4 pump It's already running dry, now it's spinning at cranking speed with zero lubrication. That pump needs diesel for cooling and lubrication. Running it dry is bad enough, but running it dry while the engine fires on ether? I'm thinking that's how you get an glitter party.
The ECU expects specific readings from all those sensors (knock, exhaust temps, rail pressure, whatever). Ether combustion would give completely different values I'd imagine. The truck would probably light up like a Christmas tree, throw codes for everything, and maybe even go into limp mode if you're lucky enough that it survives.
The actual problem Option2 had no fuel flow at all. Nothing. Ether might make it fire for 10 seconds if you're lucky, but then what? You're right back where you started, except now possibly with CP4 damage and a computer that's convinced the world ended.
Old mechanical diesels? Sure, little shot of ether in stupid cold weather, probably fine. Modern common rail with piezo injectors and a CP4 I'd keep that ether can far away.
@HeavyAssault right about the ether bunny thing. Once you create one, that's what you've got. Except with these trucks, I'm guessing it's more like an "ether corpse" because the repair bill would be the real killer.
Just my thoughts though. Maybe someone's gotten away with it? but I wont have any data ever for this test case.
Exactly why I said to destroy my post haha and you're exactly right (both of you). "Worked" on old beasts and diggers back in the day... for certain applications... I added the comment mainly to bring on some of that educational talk 🍻 good on @Option2 for not just following what people suggested in his home locale and taking the smart road to a proper solution! Most cases with the new (and highly expensive!) Vehicles out there... short cut methods do much more harm than good for most things. Always educate yourself before jumping on a quick fix suggestion from someone who didn't pay the bill for your rig!
Fueltank I agree 100%, I’ll be damned if I’m spraying a 90k truck with ether. My old tractors or a 5.9? Sure not an issue, I can’t even fathom a scenario where it would be called for. Last year I was visiting my grandmother in the way north corner of North Dakota and didn’t even think about plugging in my truck, the first night it got down to -20s and in the morning she took a min but she started right up, that was with winter blend fuel obviously but these new trucks are a whole different animal than they were back in the day for sure
Posts like this can save someone else from a bad day! Glad people got on it with what I put down! haha thanks guys! I can't count the number of people and "techs" out there who - over the fence post - suggest **** they know full well is absolutely the wrong advice because, they either don't care or, get a kick out of it for some reason... even if it's honest advice, trust your research/common sense first before following suggestions! 👍 public service announcement for the day haha.
@Option2 can we get a clear summary of what went wrong/the correct steps? That way in the future no one else is confused!
I'd like to add here too don't buy your filters off Amazon or other places... get genuine OEM from reputable sources as there's lots of counterfeit parts out there and cheap alternatives that simply are a mistake to gamble on! Just getting that in here for those that will see this down the road... 👍
Used the ether on socks for some nefarious Army stuff a long time ago. Don't think they even use ether anymore or it would go over well.
While I'm not a tech in real life, I do play one on YouTube!! 😜 😜 🤣 🤣 🤣 🤣
Seriously...I've broken enough stuff, or damn close to know better now. So I just try to help keep some sanity with the crazy aspects of these things. If we all work together and share info we do become a smarter community!!
See what happens when you listen to Wilbur - don't say I didn't warn you.
STEP A: pime by opening to accessory for 20-30 seconds -- you can hear the pump come on, feeding the system with fuel (it's okay to leave accessory open until fuel has finished feeding the secondary, you will hear the distinct drops stop).
Sorry for the late response, I was helping a buddy with his 6.0 and then raced over here to Phoenix after.
What I believe happened is the first go around the lower filter wasn’t installed correctly. By that I mean I don’t think I had the bottom cap the filter sits in fully tight and flush with the housing. I left the splash guard that goes around the lower filter housing in place. That is a mistake for the first timer. Definitely remove the splash guard even though the snaps are a PIA. Also after doing the lower and going through the prime sequence make SURE you hear your fuel pump catch fluid. The pump will go from loud to quiet with little spurts of sound as it clears more air. This part almost embarrasses me because I work around water transfer pumps all day everyday and the sound is very similar just on a lot quieter scale.
Once you hear the tone change after priming the lower filter I’d go ahead and prime it at least another half a dozen times, can’t hurt anything doing extra but not doing it enough sucks I promise. The under hood filter is super easy, hardest part is being gentle with the plastic fuel line clips. After it’s installed repeat the priming process but I don’t think you will hear any difference this time. I was able to stick my head down by the under hood filter and hear fuel flowing through the lines after I had primed it a bunch. That was the point i felt safe enough to crank it. It cranked for maybe 3-4 seconds and then fired up.
Best advice I can give is go slow, really pay attention to that lower filter housing cap, it doesn’t sit quite flush and with the splash guard blocking so much from view it’s easy to screw it up.
That’s the thing though I did do the push the button without the brake to enable the fuel pump and I definitely heard the pump, i think the first go around I did 8 cycles. Push the button and lean down and listen until the pump quit, then stand up and push the button once to turn off and once again to start the fuel pump. I heard the pump running but it wasn’t running correctly and I didn’t catch it, it must have been cavitating because it was much louder than normal. I’ve never had my head down there while I start the truck so I didn’t think anything of it even though I dang well know what a fuel pump usually sounds like, looking back all I can do is shake my head and learn from it I suppose
^^^^^^ ALL OF THE ABOVE is what needs to be learned by anyone who reads the thread. Do the above EVERY TIME and fuel filter changes get to be reasonable to do in the driveway.
@Option2 : Good on you to hang tough doing the work to get it resolved. Remember share what you learned!!
Someone should pin this... At least the last few pages could be useful as these are the types of scenarios that happen and become hours of headache for people. Experienced or not, mechanically inclined or not modern diesel/gas engines make you work for it if you take a short cut or slip up with a mistake or, think something's "easy enough" - especially with the fuel systems/electrical nowadays.
If not a pin, than maybe a section for repairs gone wrong or, "time invested as a heads up" for others to reference too.
Eg: What do you do if you just broke the fuel separator drain valve locking tabs in the parking lot and it won't go back in?
Stuff like that is, questions needing answers, for a lot of people out there. I don't know, could be a handy thing to put up on the forum! 😎 🍻
Posting answers to pop-quizes can be grounds for demerits to be issued. 🤣 🤣 🤣 🤣 🇺🇲 🇺🇲 🇺🇲 🇺🇲
Ok so my struggles aren’t quite over yet from the fuel filter fiasco! I’ve been trying to find some replacement Plastic snaps to reinstall the splash guard around the lower fuel filter housing/Diesel Fuel Conditioning Module, it’s tries abkut a dozen different variations from the usual parts stores and nothing is even semi close to working. Have found a couple roughly the correct size but they don’t have nearly enough retention IMO. Even going on ford parts suppliers I can’t even find a picture of the guard let alone the clips. Would anyone know the part # by chance?
