Did fuel filters now no start
@Option2 : Here's my $0.02....
From your first go round :
1) Under hood filter : Sounds like you had all the connections tight as there was no observed leaking.
2) Lower Filter : No leaks, just ran the pump.
Now from there given you seem to have reasonably tried to purge the lines, open the lower housing drain. Drain off any fuel that has accumulated, remove the lower filter housing. Verify the lower element is properly clicked into the holding tabs inside the lower housing, then install the lower filter/housing back into the truck. Now try the purge sequence again.
I think he’s already tried this, but at this point, going over it a third time wouldn’t hurt.
I’d run the pump without the housing in place to ensure the fuel is reaching its destination just stand out of way.
If you an aftermarket primary setup, you could fill the filter with fuel as an option before screwing it on. This can get messy however.
With the 6.0L, I would sometimes turn the key to fill the bowl before dropping in the filter, but these new diesels are so easy to prime that it’s not worth trying to reinvent the process.
I forgot to hook the WIF connector up once. Truck started and ran fine. Light came on, I stopped and snapped it on. Light went out. I hope you get it figured out.
His truck is not starting and that's the issue.
Your truck ran but threw the code.
Ok so I just got back to the truck and I dropped the bottom housing off again and tried to prime it, I’m not getting anything at all. Would lifting the back of the truck help possibly? The fuel tanks dang near full, I’m at a loss here. The low pressure pump should be like a gas engine pump and not require special priming, or so I thought it would be.
Would filling the little tray on the lower pump housing help at all, assuming I don’t spill most of it installing it back into the truck?
Did you connect the 3 fuel lines on the upper filter to the correct locations? Not sure that is even possible, but something to verify.
Yessir, each of the 3 has a very distinct clip style so I am positive they are in the right order. Theres no way I could screw up setting that plastic filter in the housing and turning it a little until it locks is there? Maybe filling that with diesel will help?
The 30amp under the hood is a funky square fuse but when I put a multimeter on it and measure resistance it’s showing 0.0 instead of OL/OC so the fuse is good. Plus I can hear the pump running when I turn ignition to Acc(hit on without pressing brake pedal)
Edit- when I put the fuse back I swapped the 30amp wiper motor fuse and the fuel pump fuse just to be sure. Wipers function and still no fuel at the lower filter housing under the bed, I can still hear the pump running as well.
Is it going proper voltage?
Could the pump be “running” but not working? If the pump was running but sucking air you would have fuel at the lower and upper filters. If there was a leak you would see it. I’m not sure what pump design ford used but the motor could be spinning without turning the impeller or whatever draws the fuel.
Gmbpilot- I would say unlikely, the truck drove great the last week, on my way back from grabbing filters I was cruising 75ish on 285 no problem, no stutters or hesitation what so ever. If I pop off the fuel line closest to the firewall on the under hood filter it will spit a little fuel when powered on to Acc. There is pressure at the smaller return line as well but no fuel. The first thing I did was swap the old filters back in and do everything again so I know those filters don’t have blockages or I’d have never made it to the parts store and back.
AZ- No sir I didn’t think to do that, I’m not entirely sure I can get the probes of my multimeter down in there, whoever decided to tuck the under hood fuse block up where it is should be shot. I will def attempt to get a reading on it tomorrow.
Does anyone know how the two nubs on top of the filter cartridge that goes in the lower housing interact with the upper housing? The one with the soft almost ‘funnel’ shape makes me thing fuel enters on that side, if that is true what’s the other harder plastic nub for? Looking up into the filter housing there is a shiny piece covering that hole. Could that be a vent of some sort? I’m thinking about calling it a night, I’m super frustrated with this dang thing, it’s dark as well so I think sleeping on it and trying again in the morning might be my best bet. If anyone knows of a diagram or article that really breaks down how this fuel system works I would be eternally grateful. I appreciate all the help so far guys!
What are the odds the pump just gives up the second I decide to do fuel filters though? While I agree it’s definitely possible the truck ran awesome until I this so I really think there’s something simple I’m missing. Fords done the filters on this truck it’s whole 89k life(easier to prove it’s been maintained for warranty as it’s my personal work truck) and this time I decided to save a few bucks but man what a mess this has turned out to be.
Pumps work until they don’t. I hope it’s a crimped seal or unplugged wire.
that is very true, it’s not like this truck has lived an easy life either. Would I be correct in assuming the low pressure pump is in the fuel tank on these trucks?
I’m not sure, my 6.7 was a 2012. If you leave the water drain open on the filter and cycle the start button does diesel come out?
This is weird. When it didn’t start and you primed the filter and then took them apart to reinstall them did you have any fuel come out of the lower filter like you would when you drained it the first time? If not there is something wrong with the pump I would assume
Good information in that link. The thermal recirculating valve and the internal check valves are possible failure points if the pump is pumping fuel.
Good point here - was the new bottom filter soaked when you pulled it?
I'm sure that would have been a no-brainer, but sometimes we can't see the forest for the trees when we're tangled in a web of chaos.
