Did fuel filters now no start
OR the smarter way is to pop off the 3 lines on the under hood filter first......Yep.....it's that easy.
Things I didn't know.... after the first time of doing it with an full tank, I made sure the rest were at an 1/4 :D
...pour diesel into the supply like (closest to firewall) at the under hood filter until it won’t take anymore ....
Just want to point out that you are doing this with the new filters right? As nothing would be worse then you did get it to start with the old filters and put all the filtered dirt into your cp4... I just want to be clear about how sensitive that pump is.
Go to about 2 minutes. That is the line I was mentioning
Ok I watched that video, I’ll try popping that off but what will that tell me? I know my lower filter housing isn’t full, and trying to prime with that off will just let more air into the system won’t it?
The trucks trying to prime but something somewhere is letting air in, therefore dealership of course won’t just sell me o rings for the fuel line fittings they want to sell the entire bundle of fuel lines and there’s no way I’m doing that job laying in this damned desert, I have sand no man should ever have sand😂
At this point I’m at a loss besides trying to figure out how to manually fill the entire lower filter housing
Fueltank- yessir the new ones are in, I’m aware of how touchy they are and I’ve been very careful so far….well obviously not careful enough with this issue happening
I just inspected the lower housing again and the Oring on the bottom cap is good, zero gaps anywhere, filled it up to the lip and installed it again, I’m almost starting to think one of the lines on top of the lower filter housing may be cracked or something. Statistically as many times as I’ve had the lower filter out I’d have got it back together right by now, something else has to be going on here, anyone know if it would be easier to lift the bed or drop the tank? Trying to do this out here is going to suck something serious I fear
So if my understanding is correct that lower filter housing is under suction.
If the 22 has the same fuel system as the 23, the lower fuel filter (DFCM) is under pressure, not suction. See picture below take from the link in my previous post. If you don't have fuel in the lower housing after priming, the problem must be either with the in-tank fuel pump, or a valve/check valve that is contacted when the filter/cover are installed. Did something come off of the old filter and is it stuck up in the filter housing? Compare the old and new filters to make sure they are identical.
The first thing I wondered was if the old filter left something in there but after pulling it and comparing it to the two separate new motor craft filters I see zero differences anywhere on any side, I also used bright light to look at both of the ‘ports’ on the top side where the top of the filter sits and I can’t see anything left behind at all, I’ll pull it again and see what it looks like but I’ve looked at it I think 3 separate times
Fuel tank I did for just a min yesterday….not for very long though, I think I may try that next. Can anyone verify their DFCM cap sits like this? I just installed it again and removed the guard around it so I can see better and it looks like it sits cockeyed? I moved the cap with filter on inside to try and feel the filter contact points fall into their holes but I really couldn’t feel anything. I did try to get that corner sucked down first and this is as tight as it will go, I wonder if I do need a new fuel filter housing, if it’s not mating up properly maybe the filter isn’t letting fuel into the housing? Also took pics to verify nothing was left behind and poked around each ‘hole’ with a pick to ensure there wasn’t a small Oring I was missing
Might be making headway! After I snapped those pics I crawled out, popped off the fuel cap and started the priming sequence, on the second cycle the pump sound most definitely changed. Going to prime it another 10 times and try to fire it up, anyway I can verify the under hood filter is full before I turn it over?
That definitely is a problem but interesting thing is, it's not leaking.
Still wondering if the new filter is soaked when you pull the housing cap?
If you were to try and install the old filter - will it seat properly?
Is the new filter defective?
You can pop the fuel line off at the under hood filter and verify flow. Put a cup under the line while cycling then start button. It should fill a cup quick.
Ok so truck is back to life now. This last time I pulled it apart to take the pictures I posted I did everything the same but took the splash guard off(broke 2 tabs so it’s staying off till I can pick some up), I poured maybe 3 cups of good clean diesel into the line that feeds the under the hood pump, jacked up the back tires approx 4” and took off the fuel cap. By the 3rd prime sequence the gurgling sound was completely gone but I could hear little pockets of air every now and then so I primed it another 10-12 times to be safe. I did notice some hazy almost foggy gas in the fuel filler neck while I was priming it. I’m not sure which one did the trick but it sure did.
Fueltank- thanks for doing that! On the smaller middle picture it looks like yours has a slight angle to it as well? Mine looks more severe for sure but I’m certain the filter was in straight and I tightened the back row of bolts a little tighter than I felt comfortable with being the housing is plastic but that little gap didn’t shrink any and this time she primed like a champ, maybe it was an accumulation of all the key cycles I tried, I have no idea but i definitely know I need to start doing a lot more reading on this truck and its systems, this is the first vehicle I’ve owned I haven’t done every bit of work on myself and that def needs to change I think.
I can’t thank everyone enough for all the suggestions and help, I’d have ended up calling a buddy and trailering this thing into town to a shop without y’all’s knowledge. I appreciate the heck out of y’all!
Can't say I've ever been as invested in somebody else's routine maintenance 😄
Was surprised to see that slight angle/gap on mine too, never removed that rock guard before when doing filters. Next time I'm starting with the back bolts first then working forward, usually do a cross pattern like wheel lugs.
We'll never know if it was the gas cap, jacking it up, or just the 47th prime cycle that finally worked, but beats the hell out of dropping the tank in the desert.
Glad you got it sorted man. This forum comes through.
Glad your back up and running.
I’ve been there. I learned the hard way on a 6.0 the filter seal has to be tight.
I’ve Never had any issues doing fuel filters because yes it is easy, I was simply replying to a comment that it does happen even Arod mentions it
Certain applications... a sniff of this can get things turning enough to clear it's lungs but, if the system has a pressure leak it won't pull the fuel anywhere. Brought a few old beasts/diggers to life in frozen climate this way without too much struggle or F-ing around although I can't say it's a recommendation haha
Then again guys dump nitrous into the air box at burnout competitions so it can't hurt too bad? Lol.
Welcome to destroy my post here for offering up this idea haha most people wouldn't suggest it I think 🤔 ETHER way it'll start for a minute or two! Lol
