Did fuel filters now no start
You were in Phoenix this weekend? You should have hollered.
You can find those retainer clips at ACE or any hardware store.
I just bought some for another application and they had different sizes available.
I’ll admit I did not check hardware stores, I tried advance auto and Oreillys. I’ll actually be back in Phx in a few days, my mom lives in Avondale so I spend a good amount of time there. This whole fuel filter thing has me kind of worried, im debating putting a DPK in the truck
That wouldn't be a bad idea and certainly would provide a piece of mind.
If you're planning to keep the truck, you might considering just swapping the pump all together and become part of the DCR club.
The DCR kit would definitely be preferred. Im planning on running through the S&S instructions on the DCR swap later this evening when we stop for the night. I think the DPK would be doable in Phoenix but definitely not out at work. I don’t even know any diesel shops in that area, I’d be curious what they’d charge to install the DCR. I only have a few thousand miles of warranty left so it’ll be time for a ‘weight loss’ program here before long. This is the longest I’ve ever retained a warranty in my entire life😂
There's no such thing as a "cold air intake" for these trucks. 😎 😎 😎 🇺🇲 🇺🇲 🇺🇲 🇺🇲
I don’t think I’d benefit from one either way, the environment my truck runs in most of the time is just way too dusty, I wouldn’t think any ‘high flow’ filter would catch it all. I could be wrong though🤔
@Option2 : I'd suggest a filter pre-wrap for any application one chooses. 😎 😎 🇺🇲 🇺🇲 🇺🇲 🇺🇲
Both our truck have DCR
If anyone needs a Cp4 pump
I have two of them with around 2k miles
They are shelf art now
I have mine sitting on the shelf as well.
I haven't tried to sell it; not sure if there's a market for it?
I'd let it go for cheap, especially to anyone on the forum -- because realistically, if you're performing that surgery, you might as well drop a DCR in there.
If money is tight, it certainly can be plan B.
Since we are talking filters
Here’s one of our air cleaner filters at 10k miles
Not a fan of fords air box set up / or ease of changing filter
Looking into after garbage air box
Any suggestions ?
SPE is coming out with a closed air box soon
Zooming in, it doesn't look too bad really. It appears to be doing its job. What do the pleats underneath look like?
What’ does a DCR conversion run roughly? I see the kit is $2400, the factory CP4 isn’t buried like the one on my 6.4 was, but I’m assuming it still takes at least a handful of hours to do the swap?
It was really not to bad
For a truck that’s never been in rain ( garage queen)
Was surprised how dirty pre filter was
Guessing due to clean air supply facing front
Ours were 1900.00 for kits
When we purchased
About 8hr install In our home shop with no beer
12 hrs with beer
We also did exhaust wt reduction at same time
Local diesel shop by me has 55gal drum full of cp4 pumps so probably zero value
My sloppy Joe post got nuked almost as fast as I posted it haha 🤣 all I'll say is... the only thing I want to give any of them is a wave goodbye 👋 haha.
That's what I thought about the diaper bag when I lost it; turns out that years later, it's a hot commodity.
So did the truck start?
I will remove the fuel filler cap and listen for the pump to flow back into the tank. It's a different sound when the air is purged out, going for an aeration with intermittent gurgling to a steady state liquid flow into the tank.
Can you describe what you hear?
It runs about 6-8 hours of labor.
The entire intake system must come out to get to the pump, a charge pipe, and disconnecting some EGR tubes.
What sucks is having to put most of this stuff back when you could realistically eliminate 50% and go straight pipes.
Kill two birds with one stone.
It's documented very well throughout the thread, specifically post #73, 81 and 93.
