Also, where did you buy the filters?
Be glad it didn't happen while making it back to base, stuttering the entire way.What are the odds the pump just gives up the second I decide to do fuel filters though? While I agree it’s definitely possible the truck ran awesome until I this so I really think there’s something simple I’m missing. Fords done the filters on this truck it’s whole 89k life(easier to prove it’s been maintained for warranty as it’s my personal work truck) and this time I decided to save a few bucks but man what a mess this has turned out to be.
I believe in Mike.I think you're dealing with something simpler than a dead pump.
Since you've got an almost full tank, you'd get at least some fuel to the lower housing even with a completely dead lift pump, gravity would handle that at 7/8 tank. The fact you're getting zero fuel flow suggests a blockage rather than a pump failure. Plus, you mentioned the old filters didn't work either when you put them back in, and those were working fine before. That points to an installation issue rather than bad parts.
The lower fuel filter can be tricky, it needs to slide and click firmly into place. You should feel it positively lock into the housing tabs. If it's not fully seated, it can block the fuel inlet or prevent the check valve from operating correctly. Make sure you're pushing with enough force to feel it mechanically lock.
One thing to be really careful about, cranking the engine without fuel flow is hard on your CP4 pump. These high pressure pumps rely on diesel for lubrication, and running them dry can cause expensive damage. After this many attempts, I'd stop cranking until you solve the fuel flow issue and your engine bay has an little diesel in it from leaving the upper lines off.
Pull that lower filter one more time and really inspect how it's seating. Look inside the housing for the locking tabs and make sure the filter cartridge is fully engaged with them. Sometimes it feels like it's in but it's just resting there without being locked. Given that your old filters won't work either, something's preventing proper flow through that housing.
The pump suddenly dying right when you changed filters would be pretty remarkable timing.
Exactly! This is what I meant by “blocked” fuel filter. Very possible it’s not seated correctly essentially blocking fuel from entering the lower housing.The lower fuel filter can be tricky, it needs to slide and click firmly into place. You should feel it positively lock into the housing tabs. If it's not fully seated, it can block the fuel inlet or prevent the check valve from operating correctly. Make sure you're pushing with enough force to feel it mechanically lock.
BTW arod says that disconnecting this line helps decrease the amount of diesel that drains from the pan when you are changing the lower filter and have more than a quarter tank of fuel.
I agree, and not to hijack the thread, but we have all seen posts from people who claim they have drained five gallons from the lower housing before it quits draining. This is for those “other people”. LolMy experiences is that the amount drained out os about 1/2 a gallon. So if that's important to some people I'd think the effort to stop that loss is worth the effort.
Not 5 gallons but I got almost 2 gallons out once. Well it was my first time doing a filter change. Just fuel up on my way home from the auto part store with new filters. Took forever to drain.I agree, and not to hijack the thread, but we have all seen posts from people who claim they have drained five gallons from the lower housing before it quits draining. This is for those “other people”. Lol
Normally yes, but siphoning can happen with these trucks and won’t stop till you’re damn near empty or you bite the bullet and pull the filter quick to get the check valve to engageMy experiences is that the amount drained out os about 1/2 a gallon. So if that's important to some people I'd think the effort to stop that loss is worth the effort.
This^OR the smarter way is to pop off the 3 lines on the under hood filter first......Yep.....it's that easy.
Rolind- there are four lines on top that go into the DFCM-lower filter housing, I’m assuming you’re talking about the easy to reach one? If this literature is correct the one I’d want to take off and check is a lot tighter to get to, not sure I’d be able to with the tank mounted still https://www.forddoctorsdts.com/forums/topic/7215-fuel-line-identification/
AZ tested volts when in ACC mode on that fuse block, it hovered right around 9.8-10 output, I didn’t think to try amps but I can this morning, that damn fuse cover is PIA
So if my understanding is correct that lower filter housing is under suction. The only place I can think I’d be getting air there is the seal around the cover or the water drain but the new water drain is in. This morning I’m starting out pulling the bottom filter again. Filling it as full as I can with diesel, reinstalling it, then popping off the supply line under the hood and filling it with diesel until it won’t take anymore and trying it again. Hopefully getting some fuel in there will show me where I’m getting air if I am indeed getting air and don’t have a bad pump
Where’s the bleed screw and hand pump on these? I wasn’t aware they even had one….Sounds like you might be vapor/air locked. Had this happen on a boat once while going up river. Fuel cut out, had air in the line. Priming didn't help at all. Had to suck the line to force fuel which eventually resolved the problem. Hope you get it resolved soon!
