View attachment 115458TL;DR- My shell doesn't lock/unlock as intended and I need wiring schematics.. but the ARE Z Series looks great!
I bought a used ARE Z series for my 2022 F350 with lock/unlock functions and am trying to wire it up. I tapped the drivers side door sill wiring (gray/brown and green/brown) but am getting weird symptoms when trying to lock/unlock the shell. The wiring from the door sill to the ARE module does not activate the lock/unlock functions.
Symptom: With the wiring attached to the ARE power box module as intended, when locking the truck the reverse lights flash for a fraction of a second. The cap does not lock/unlock. I can pull the wires and the reverse lights to not flash.
I feel that this symptom is some sort of back feed into the circuit, but for the life of me cannot figure out how or why. I'm not sure if this is the proper verbiage, but I do know that the reverse lights shouldn't activate.
I have tried reversing the wires that I tapped without success. My only thought now is the wires I have tapped are not correct. The picture attached is the two wires I have tapped, the yellow highlighted circle is a wire that I initially thought was gray/brown and tapped it first. When that tap didn't work, I changed it. Maybe I shorted a circuit accidentally? (I did run the BdyCM through Forscan and didn't have any DTC's populate.)
I have tried to find the wiring schematics for my 2022 but am coming up empty handed. Does anybody have any input to my problem or maybe knows where to find the schematics?
Mickey
