So basically right now we don’t know if this was a rating/testing change or a physical component change to combine the 6.8 and 7.3?
Common sense states, if it were just a decrease due to testing to different SAE standards or fuel type, Ford would have stated as much to prevent/minimize the blow back - which they knew would come. As they have not even attempted to get out in front of this, to me, it only confirms the loss is real. No way Ford Marketing missed this.So basically right now we don’t know if this was a rating/testing change or a physical component change to combine the 6.8 and 7.3?
I agree. The full-size truck segment is intensely competitive and highly profitable for the manufacturers. Zero chance Ford wouldn't have tried to put some positive spin on it if they could, and zero chance they would have lightly relinquished the "best in class" title.Common sense states, if it were just a decrease due to testing to different SAE standards or fuel type, Ford would have stated as much to prevent/minimize the blow back - which they knew would come. As they have not even attempted to get out in front of this, to me, it only confirms the loss is real. No way Ford Marketing missed this.
Instead, the most discussed change is a drop in its officially advertised ratings to 420 horsepower and 445 lb-ft of torque (down from 430 hp and 485 lb-ft). This reduction is not due to a physical detuning or engine change, but rather a shift to the stricter SAE J1349 testing standard, which mandates factoring in heavy-duty cooling fan mechanical losses during dyno testing.[4, 5]
False. You will be able to see the parts # changes in the catalog shortly for the intake manifold, exhaust manifolds, throttle body, new front cover. It is physical changes to the engine per multiple people at Ford. Stop relying on junky AI that doesn’t know right from left.There's your "cam change".
I thought I was among friends, here; like-minded gearheads. Instead this has turned into a paranoid witch hunt.
Someone else has recently said:
"Guys, let's look at the actual data instead of chasing camshaft ghosts. Ford dropped the base 6.8L gas engine and made the 7.3L standard. When they did this, they re-certified the engine under the stricter SAE J1349 standard, which mandates factoring in heavy-duty cooling fan losses.
Think about the math: a 40 lb-ft drop (from 485 to 445) is the exact parasitic load profile of a fully locked, heavy-duty mechanical truck fan spinning at peak torque RPM. Ford has already confirmed to truck journalists that there are no physical restrictions like Gasoline Particulate Filters (GPFs) added to the truck. The physical engine is the same. The truck will pull exactly the same. Stop looking for a 'stealth cam'—the only thing that changed is the strictness of the accounting math."
...and I agree 100%. My 2025 F350 Godzilla Tremor's output is equally affected, again, every time my engine cooling fan clutch engages.
You are wrongI am not wrong.
Period.
It is a RATING change, and you are simply at this point causing trouble.
Cheers.
That’s not a source. That’s AI that is pulling from discussions from forums like this and news articles. It doesn’t know anything. Do you believe those AI videos you see on Facebook of gorillas saving the kid after it falls in the enclosure too?
Whatever you say, pal.
You will refer to https://www.fordtremor.com/threads/7-3-to-lose-40-lb-ft-of-tq-and-10-hp-for-2027.24742/post-571110
If "the Fan" were the reason for the reduction in power rating, why hasn't Ford just come out with a release to state that? Wouldn't that be the simple thing to do to help protect their brand and clear the air? But they haven't done that which, to me, speaks volumes that this is a true reduction in power. Had Ford come out and made such a statement I'd be driving a 2027 right now, but since they didn't, and hearing from Ford executives (via my dealership) confirming the power reduction, I canceled my order and bought a deeply discounted 2026. Which I knew for a fact wasn't derated. I'm not a gambling man and will always take the known vs unknown when given the chance..Oh, it's real, alright.
Every time my cooling fan engages, there goes 40 HP.
I ain't lyin'.
It's a RATINGS change. It's a CHANGE in how the engine's output is rated.
But, go ahead and keep clutching yer pearls, ladies.
Just a question out of curiosity. You have mentioned dozens of times in this long thread that the GM motor is more suited to what you are looking for, why are you not buying one and letting this thread die?False. You will be able to see the parts # changes in the catalog shortly for the intake manifold, exhaust manifolds, throttle body, new front cover. It is physical changes to the engine per multiple people at Ford. Stop relying on junky AI that doesn’t know right from left.
Ford started counting the fan in 2023. The only reason they are adding that note is to make it look not so bad now. That note wasn’t needed before because it wasn’t neutered down.
Some people have it on pretty good authority that GM is doing the opposite to troll Ford and actually increasing output of the 6.6 for 2027 model year. No reason to buy a 7.3 when it’s getting seriously out-competed in my eyes. I also wouldn’t buy the HO Powerstroke when a Duramax GMC is a much better deal with better incentives and interest offers.
Probably because nobody outside of like the 0.0001% of enthusiasts even noticed or actually gives a f***? Ford sells nearly half a million trucks a year, and 99.999% of owners toss the window sticker and marketing brochures in the trash can at the dealership and just put the key in the ignition and drive off.If "the Fan" were the reason for the reduction in power rating, why hasn't Ford just come out with a release to state that? Wouldn't that be the simple thing to do to help protect their brand and clear the air? But they haven't done that which, to me, speaks volumes that this is a true reduction in power. Had Ford come out and made such a statement I'd be driving a 2027 right now, but since they didn't, and hearing from Ford executives (via my dealership) confirming the power reduction, I canceled my order and bought a deeply discounted 2026. Which I knew for a fact wasn't derated. I'm not a gambling man and will always take the known vs unknown when given the chance..
Yep you're right, why would anyone care about the power rating when buying a 1 Ton truck. How silly of me..Probably because nobody outside of like the 0.0001% of enthusiasts even noticed or actually gives a f***? Ford sells nearly half a million trucks a year, and 99.999% of owners toss the window sticker and marketing brochures in the trash can at the dealership and just put the key in the ignition and drive off.
A dozen people on an internet forum demanding "tHeY sHoULd ReLEAsE A sTAteMEnT!" doesnt even register.
