1. I'm not a rat and this problem is real, but I see that was also explained above. It's worth a look because I did find dog food in the in-cabin air filter when I swapped it 18 months ago.
2. The "click" title in this thread should have been "clicks" (2 of them). One comes from the BCM area (passenger floor board) and then 1 comes from, I believe the starter immediately after. Then, nothing.
4. The issue/noises is the exact same now as it was before the new starter, new fuse box (under hood), new batteries, new BCM, new key fob batteries.
1. Dogfood in cabin air filter likely means you had an unintended pet though I'm unsure how much access there is through the firewall to get up into the dash electrical... not to mention you would likely literally smell a rat... proximity of the cabin air filter to critical wiring harnesses above in the engine compartment however, I would be using a mirror and a flash light tracing connections for damage signs from the engine compartment down onto the frame rails even.
2. Power is being sent. This is where the voltages need to be tested as the threshold for starting is intermittent and likely has a fault somewhere between, that sometimes has enough to initiate the start and, other times not enough. Likely bad wiring once again.
4. These replacements just eliminate possible causes and once again point to wiring and going through the truck looking for damage to the harnesses.
Hopefully you won't need to tear into the dash but there are areas you can inspect there without taking too much off, I'd highly suggest pulling the globe box/fuse panel and drivers side panels to look for water/damage or even further sign of animal's spending time in the area.
The reason voltage/ohm testing is so important is finding a small chewed spot deep in the engine compartment into a harness that may be in a few different locations... but small enough it's like finding a needle in a haystack the testing can let you know if the harness supplying the power is failed or out of spec enough that it causes the issue with a good degree of certainty.
I'm fairly confident that will be what it is at this point you've covered most everything else in the chain from what was replaced. Kinda sucks the starter got replaced in a way too if the wiring is the issue it could potentially damage the new starter or other components just shorting out. Need to do a deep dive on the wiring I would say.
