1 loud click, no start
At this point, this thread has become my diary.
I'm having the truck properly diagnosed this week.
Today, it left me stranded about 15 miles from home and I had to get a ride.
Looks like we're on an every 2-3 week cadence with no hot, cold, dry, wet similarities... it's totally random.
Has to be the ground from the engine to the frame, or frame to battery.
I've searched high and low for some sort of diagram to help me find them. I just crawled down out of the engine bay a moment ago, on the hunt for those ground points.
Now I'm about to crawl under.
Every time... It just needs about 45 minutes to an hour and it will start right up.
Welp, I never got around to double-checking the work from the guys that replaced the starter for me. Low and behold, there's a 15 mm nut holding a pretty hefty connection on at the back that's loose as all hell.
That has to have something to do with my issue.
loose ground would cause your issue
Welp, the loose wire on the starter wasn't the problem. I went to leave this afternoon and it wouldn't start. Checked all battery connect, slapped the fuse box upside the head, stood on one foot and then it started on the 12th-ish attempt.
It's going to my mechanic tomorrow for the in-depth troubleshooting.
Update: Not sure if the problem has been solved, but now there is a new one.
I picked up the truck from my diesel mechanic buddy last Friday and the truck has been starting just fine but that's not a long enough amount of time to truly know if the problem has been fixed. He ran through all the diagnostic steps provided by the community above and could not find any issues. For good measure, they disconnected all of the grounds and power cables, cleaned them, and retightened everything to make sure we didn't have a loose wire.
But!
Now I have a different problem. Since picking the truck up, the starter is now making a horrible gear grinding noise. Kind of like back in the day when you could still turn the key and engage the starter when the vehicle was running and you would hear a very loud grinding noise. What I'm hearing is even louder than that.
Son of a!
Got mad and dove all the way in, only to find a connection to the starter, the small one, was just floating on there with no nut. No wonder it sparked!
Found a nut that fit and tightened it the best I could. No problems for 4 days.
Sounds like your starter wire or something got pinched. You may not see it but if it got partially severed, that would cause your issues.
@TremorSS I can attempt ot trace that and find out. I also recall you mentioning ground points on the frame, which I have been unable to find. I found the ones that attach to the firewall, on both driver and passenger sides, and they look good.
@4wheels and a hitch that was step 1 a year ago. I've also replaced the batteries and the entire fuse box.
No rhyme or reason. It doesn't matter if it's hot or cold outside, wet or dry, cold start or after a short/medium/long drive. It's completely random and will go away for weeks/months at a time and come back with no apparent trigger.
Maybe it's not an electrical issue...
To reiterate earlier comments, you may have to actually measure the voltage at the exact time it clicks to see if you have a drop in the wire. A drop would indicate a heavy load or draw and could indicate an electrical issue. If the voltage does not drop at the starter connection while measured DIRECTLY on the starter, then the starter motor is not going all the way into the engine and the heavy voltage, which makes contact only after the starter is mechanically seated into the gears, will never be applied to the actual motor armature. In all likeliness, the voltage will not drop under those conditions. This would indicate the armature is not being engaged.
If this is the case, you may have a mechanical issue with the flywheel; perhaps a damaged tooth that the starter is banging on, warped flywheel, or the face of the starter mount is misaligned, or even machined wrong, which will also cause the teeth not to mesh properly. You may have to take it to a dealer and have them inspect with a scope to determine why it doesn't engage.
The fact that it doesn't always happen indicates the battery connections are probably OK. The loose cables you have experienced is likely sloppy workmanship from whomever inspected it for the issue. (Dealer possibly)
I've been hesitant to post this, because maybe I'm just a little bit superstitious, and didn't want this to cause the problem to come back.
It's been 4 weeks since I took my truck to a local diesel shop and asked them to try and find the electrical gremlin that would cause my truck not to start, for no rhyme or reason.
They were unable to reproduce the problem, which limited their ability to track it down, but right before I went to pick the truck up we had a conversation about checking for codes. The codes they found did not have anything to do with the starting issue, but then they made a comment about needing to see a "U code" to help them out, but there weren't any.
Then, I remembered when I was poking around on my EZ link and noticed some U codes after a tune. That is its own separate long story (resolved) but when I shared what the code was, they said that that could be the BCM.
They shared some stories about having to replace a few of those that went bad or were just defective from COVID era trucks. We couldn't find any water intrusions or anything obvious that would have caused damage to the BCM, but I decided to have them go ahead and replace it. It wasn't cheap and they had to have some special locksmith go through a process to assign my key fobs to the new BCM but they got it done.
It's been 4 weeks in the issue has not presented itself again. I'm even getting a bit brave and turning off my truck when I have to go into Home Depot or even pump fuel.
Fingers crossed!
I'm pulling this thought from out of nowhere so, consider it just trying to help...
Push button start or key ignition... is there any possibility the connections there/ignition cylinder itself could be faulty or triggering the vehicle security to prevent starting? 🤔
@Canyon Trekker @JTredway @ccradier @HeavyAssault @Dude
there are people here who may (or not) have some ideas to throw at this... I remember seeing something once about a woman who had put a decorative metal ring around her button start (bedazzled jewelry crap) and the vehicle security prevented starting from it being there due to proximity immobilizer or something.
Just wondering if the fault could be at the button or key ignition cylinder/maybe the brake switch is faulty?
Not sure... just throwing ideas out. Maybe someone will join the convo here to help get this resolved for you... If it's not the starter then gotta start throwing ideas until something sticks I guess 🤷
Good luck man.
I appreciate the reply. I actually bought a new button but never installed it because the problem persists on remote start as well.
Thats actually helpful information though, process of elimination. Simple to complicated, eventually the issue will be found. Just crossing fingers it's cheap and stupid like a spring break lay haha...
Wish you all the best man 👍
