1 loud click, no start
Two months and it started happening again, ugh. I agree that it needs to be determined whether or not it is wiring resistance issue or a logic control comms issue.
I wonder if somehow the PATS is causing the starter/BCM to disconnect JUST before the starting cycle kicks in. But then there is no "security alarm"....no code...... :unsure: :unsure: :unsure: :unsure: :unsure:
Finding the grounds isn't hard, just a little time consuming. No likely "just one spot" needing a ground would cause this issue. God I hope you don't need to tear out the dash to find a wire cut JUST enough that it's tripping the BCM into pause on start. :unsure::unsure::unsure::unsure:
Man this fix is deep in the weeds it would seem. F-k.....
I've got an old forklift that when you turn the key in the ignition everything lights up like there is no problem, but won't turn the starter. Giver 'er the ol' reach around and jangle some wires back there and boom, starts right up. So, I think @Aaron24F350 might be on to something, even if the remote start also exhibits the issue, if there is a wiring issue back there, the truck could be getting sent some mixed networking signals.
On a separate note, a ways back in the thread you mentioned the starter making some terrible noise. What was the resolution of that? With the start making noise and the wiring having two pretty significant issues, are we sure there isn't a bigger problem with the starter and either A) there is a mechanical issue, as mentioned before and it is setting off a sensor and the truck is maybe doing what it should or B) that due to the shorts that were happening with the wire is something up or down the line fried and causing a sensor communication issue?
All that being said, may be a wild goose chase but worth doing for peace of mind, but it sounds like the issue started prior to replacing the starter, is that correct?
If so, for this particular issue, the starter may be a side quest.
If you ever needed an excuse to buy a banks pedal monster, this may be a good one. The I dash pro (you can buy it by itself if you want) has a pretty huge amount of data logging and since it plugs into you OBD you get a lot of information and error codes. I would maybe call and talk to banks first to see if it might help as a diagnostic tool.
Lastly, can you re-cap any of the info from the very beginning of the issue prior to attempting any fixes.
can you confirm if the starter clicks at all or is the click in the video a relay or something under the hood? the click and non start of the starter is a very important electrical path detail
sometimes in the battery cable itself there can be corrosion inside the crimp that can cause issues, it can look fine, but not be. Check the negative cable all the way back to its connection point. Or just replace the cable. This is most important on the passenger side battery.
Next, get your multimeter and check for voltage drop during crank, like others have suggested. Really nothing else matters until this test is done. Make sure the multimeter is in DC mode and put lead A on the negative battery post of the passenger side, this is the primary reference ground for all the computer stuff, then put lead B on starter housing. Try cranking. You should see < 0.3V if it is .5v+ then there is a ground problem
The next critical test is similar but to the BCM metal housing. The BCM may have been replaced but still have an issue. Same as above negative battery post passenger side, B lead to BCM metal housing or the ground wire. Anything over .2-.3v there is a problem there.
Find the engine ground strap make sure that is a solid connection and not corroded.
Lastly, it could also be something with either the brake pedal position sensor or the park sensor. Do the brake lights consistently stay on every time you try to crank? Try cranking when pressing hard on the pedal, release and press hard again. If it isn't sensing the brake pedal position it could "de authorize" start, though this doesn't really jive with the remote start.
The sensing in Park could be an interesting one. Try starting in Neutral. If that works consistently that may lead to a PRNDL signal issue. You can also try physically manipulating the shifter and wiggling it around. In both of those cases it wouldn't necessarily always throw a code as you can attempt to start the truck incorrectly ie foot not on brake or gear not fully engaged without throwing a code. Though I would think it would say something on the dash. And the fact that you briefly get the warning of the charging system, I still lean toward a ground issue or voltage drop.
That's my 2 cents thus far. Keep reporting back and as we narrow things down we will find the culprit.
FYI, the issue started before any mods to the truck. The video linked below was taken ~2 years and 50,000 miles ago.
Issue
1 click, no start = clicking from the BCM (passenger foot area), then a starter click, then nothing. Video of it happening
It's completely random, no rhyme or reason:
  • Wet or dry
  • Cold or hot
  • First start of the day, or after driving (any distance)
  • Might happen twice in a day or go several months with no issue
  • Remote start or pressing the start button with the key in the truck
  • New batteries in fobs
Attempted Fixes with weeks/months between them
  • Replaced the starter
  • Replaced the fuse box under the hood, passenger side
  • Replaced both batteries
  • Replaced the BCM (2 months ago)
Diagnostics Performed
  • Charging system tested, no issues
  • All battery terminals checked
  • Starter connections checked
  • *unclear* if the shop performed a detailed ground wire hunt
  • *unclear* if the shop performed voltage tests
OK, New theory. Thanks to @ccradier for supplying the schematics above. When you said loud click, I was expecting the loud click of the starter, not the relay in the BJB. To me, that is not a loud click, but then I'm partially deaf anyway. 🤪
For some reason, I did not see that video when you first posted it. But it is telling, the BJB relay is not energizing the integrated starter relay. A very simple test can be to put a voltmeter on the F24 30A fuse in the BJB and observe when clicking the PB. You should see 12.5 volts on that fuse when the PB is engaged. Since the relay is "clicking", it says the circuitry up to that point is OK. Assuming the BJB relay is indeed the one clicking, (you can prove this by simply pulling it and see if the "clicking" goes away) the relay contacts or connection to the BJB where it plugs in is possibly not making a good contact or the wire from the BJB box to the starter is not making contact intermittently. This will cause no voltage (or low voltage) to be routed to the starter relay on the starter and not start, but you would hear the telltale click of the BJB relay. Since the starter was replaced, it is likely not that integrated relay causing the issue.
As I said, this should be an easy problem to diagnose with a voltmeter. There is no exotic electronics involved based on the problem description. It is simply a conduction issue from the relay in the BJB to the starter or the starter is not actuating the integrated relay of the motor. In theory, you could bypass that connection with a simple wire that will handle 30A to bypass the Violet Green wire to the positive battery terminal. (Just to start, not permanently) I know you said you replaced the BJB, but it appears the BJB box or the wire going to the starter is not making contact. However, if there is voltage at the starter (Violet/Green wire) when the PB is engaged, then we're back to square one, the starter is not engaging for some reason, which again, can be located by measuring it with a voltmeter.
One other caveat, if the BJB was replaced and corrosion WAS found, there could still be corrosion on the connector in the harness. I wouldn't put it past, that the dealer did not check for that.
Hopefully, someone local can come and help you isolate the issue.
I smell a rat......
I smell a rat......
If this is referring to OP being fake... lol if that's the case... then that's loser level commitment to fucking with a forum for 2 years. I'd like to have more confidence in the human race then that... but, then again this is the internet! 😆
On a different note... rats could also be a cause of the issue here lol 😆 you'd have some obvious sign though you'd think?
If this was a BS thread to waste people's time well... still good content for anyone else trying to troubleshoot issues so 🤷 get fucked! Lol no harm done here in trying to help!
That's all I gotta say on that! Haha
Easy bruh……..it was referring to an ACTUAL rat.
Buddy of mine just bought a 25 Lariat dually and had a no start last month.
The harness had been chewed by rats.
Same thing happened to a neighbor on his Side by side.
Sorry,
Next time I’ll just say “see if your harness has been chewed on by rats” that way people won’t get upset.
Sorry,
So... I dont get to fight anyone?
Fuck, why do I even show up here anymore! 😆 🤣
Thanks for the clarification sir! Hahaa
Sorry,
Good suggestion but the reason this is "probably" not the issue is that if the rat chewed through the wire, it would likely not work at all. Since it is intermittent, it screams poor connection.
Late to the game, I bet there is a sense issue with the ignition for PATs, old ford excursions and such would have wiring harness chaff from the wheel moving up and down on the column and it would wig out the key sense. Some volkswagens/audi groups I am apart of had weird issues happen when similar harness clockspring harness would go bad (all runs through same harness). Did all the relays get replaced when they replaced the BJB?
I would try to remove the little cubby under the nondrink side of the center console and put your key there or up by the button, press and HOLD the engine start button. Since it seems to be intermittent, like @Canyon Trekker mentioned, I think there's weird voltage anomaly.
Too late now on starter, next time bridge the solenoid to see if it would still kick out the bendix and start the truck once it's in run mode, could've ruled out the starter pretty quickly, skimmed so I didnt see this suggestion for future. I'll read some more later and brainstorm.
Wow. Thanks, gents. A lot to answer/catch up on here.
1. I'm not a rat and this problem is real, but I see that was also explained above. It's worth a look because I did find dog food in the in-cabin air filter when I swapped it 18 months ago.
2. The "click" title in this thread should have been "clicks" (2 of them). One comes from the BCM area (passenger floor board) and then 1 comes from, I believe the starter immediately after. Then, nothing.
3. I did try the key fob in the slot under the console tray area thing, didn't help.
4. The issue/noises is the exact same now as it was before the new starter, new fuse box (under hood), new batteries, new BCM, new key fob batteries.
I am due to drop the truck at a local Diesel shop tomorrow morning and I am sharing all of this with them.
I am also headed out now to buy a voltmeter to try some of these things myself.
I will report back. Thanks again!!!
I didn't take the rat comment derogatory and I don't think that poster meant it that way. I think they truly meant a rat/mouse issues.
There's a lot a relays and modules in that lower passenger footwell. Could be a bad relay and easy swap.
Pull the carpet check for water signs. I had an 2018 f150 with water intrusion from a Christmas tree grommet push pin that held the junction box to the inner wall. That push pin penetrated to an exterior section that would wick water inn every time it rained.
My interior guy caught after putting the truck under a sprinkler for ten minutes. Solved my sunroof drain issue as not being a leaky sunroof.
Well, back to square one. If you hear "two" clicks, then the BJB relay is working to some extent, the feed is now the question. And again, voltage measurements are critical here. This could be due to corrosion in the BJB relay junction not supplying enough current to the starter coil, to allow it to engage into the motor flywheel.
If the voltage at the starter drops after the click, you likely have high resistance in the wire going to it from the BJB relay. There are more caveats in this test perhaps too much to go into here. (Coil resistance, current required by the starter relay, resistance of the OEM wire to calculate a "normal" drop, etc.)
Test: Bypass the wire. You will likely need two people to do this. One to press the brake after turning the truck on, the other to touch the wire to the starter. Take a lead from the battery post and touch the relay wire at the starter. If it engages and cranks, more proof you have a bad wire.
If the voltage measures good at the starter when it clicks, the starter is not engaging into the motor. Have your diesel mechanic look at the mechanical alignment of the starter, have him check the teeth on the flywheel.
Does this have to be done only when it's not starting or can we find issues when it appears normal?
Ideally, yes, it would be more revealing if the system is at fault stage. However, there are certainly tests that can be performed when it is "normal" to determine if there is a drop in voltage. However, it will take some knowledge of what to look for. One thing I would check is to put a load on the starter wire at the starter to see if there is an abnormal drop. An easy way to do this is to attach the load to the starter wire and make some measurements. Sometimes with a connection issue, the voltage will look "unstable". (No solid voltage reading)
A starter coil will draw (most likely) around 10-15 amps under normal conditions. (Based on a 30A fuse for the feed to the starter coil and typical fuse size of twice the operating current.) With that as a starting point, an equivalent resistance would be around 1-2 ohms at the starter coil. (Not the armature, that will likely be near a short at .1 ohms or less.) But measuring an equivalent load of the coil would take a very large ~12-watt resistor to test that way. Instead, if you disconnected the wire at the starter and put any load on it (like an off-road light) with a known current draw, you could calculate the resistance in the wire by measuring the voltage at the load point. The difference between the voltage at the battery and the load point on the starter wire (with a load attached) will tell how much voltage is lost in the circuit. It gets complicated if you don't understand ohms law. Your diesel mechanic may know this stuff but honestly, there are probably fewer mechanics that truly understand this stuff, and those that do are likely very good mechanics with a reputation for finding issues like this.
I wish I could tell you more things to look for but without hands on experience, it's difficult to analyze. My gut feeling is that it is likely a connection issue and most other areas can be eliminated simply because you have "two clicks". The other facts that you have codes associated with charging system is a different avenue that can be attributed to the fact that the truck did not start, (as the computer is expecting since you have the two clicks) or you may have corrosion or damage in the wires under the BJB.
One other thing to remember is that even though both relays sound like they are operating, the "feed" from the relay is a separate 12.5 volts through the relay contacts. One poster suggested, and I will repeat, did you use a new starter relay or was the old relay put into the new BJB? The relay could be the issue. It may supply enough current to energize the starter coil, but not enough to push the bendix into the engine.
Honestly I didn't either, just having fun with the posts lol... OP was MIA for a while so, took the opportunity to jump on the rat comment to keep the thread alive with some entertainment.
Stuff like that does happen though... no idea what people get out of trolling like that.
