1 loud click, no start
Yup, because I need the towing capacity.
To be fair, it is -30F here today so the weird noise could be some unrelated struggling!
This video was taken after being plugged in for ~4 hours… I have not driven it all winter up until around 3 days ago (coincidentally my other vehicle had a failure & this was my “backup”… when it rains it pours!). It had this no crank/no start issue one or two key cycles when trying to start the previous days, and when it did turn on it fired right up with no slow crank or delay. The issue only presented itself the first start of the day and did not reoccur once warm. Up until this, it has ran great both summer & winter since new.
Today it is flat out refusing to start, and I have given it a good 15-20 attempts. I am running original batteries, and did note that my voltage was ~11.4v but jumper packs made no difference.
I am hoping that new batteries/BJB do the trick for me & it’s nothing more dire. I will keep all updated as I work through diagnostics, planning on doing some isolation testing and circuit checks as soon as it warms up a little.
For what it's worth, when mine first started doing this all I had to do was press the button 4-10 times and it would eventually start. This was in 70° weather, so no "waiting to start" cold weather stuff.
Then, it just got worse and now it's anywhere between 1 and 4 hours it needs to start after the initial failure.
Mine was the BJB, replaced and fixed it 100%!
I did however take this as a que to not wait on trading in for a 7.3 gas engine model (long story, but I want this to be a 20-30 year truck and believe the gas will offer better long term costs..).
I hope it is. I thought mine was fixed and it came back a few months later.
After all the BS I've been through I refuse to claim victory, but it's been fully functional since I last posted. So, I'm at about 5 months since the last failure.
Back in the day we would get a long pry bar and a mallot and lightly “tap” the starter while trying to start. If it would start while talking it’s certainly a bad starter. If it still doesn’t start it doesn’t necessarily mean the starter isn’t still bad but if it does start while tapping it’s 100% the starter. This is because sometimes the starter motor internal components, are lodged, or the brushes are seized, and this tapping will un seize the components temporarily and allow the vehicle to start.
Back in the day we would get a long pry bar and a Malloy and lightly “tap” the starter while trying to start. If it would start while talking it’s certainly a bad starter. If it still doesn’t start it doesn’t necessarily mean the starter isn’t still bad but if it does start while tapping it’s 100% the starter. This is because sometimes the starter motor internal components, are lodged, or the brushes are seized, and this tapping will un seize the components temporarily and allow the vehicle to start.
Yup. We used to do that too, and I tried it on this truck, but the story here includes a new starter, BJB, new batteries, and a new PCM.
Excellent to hear! Hoping this is the end of your no start journey.
You're not going to believe this shit!
I drove the truck to lunch and now it won't start.
Doing the battery disconnect test now...
P06E9
Initially I only disconnected the batteries, positive and negative, for about 2 minutes. No dice.
Then, I decided to disconnect both of them hold the cables together for a few seconds on both batteries and left them disconnected for approximately 30 minutes.
After reconnecting everything the truck started right up.
According to the local diesel shop, they said that would be an indication that the PCM was bad.
Thoughts?
Not with the 7,500# dump trailer attached to it.
P06E9
Thoughts?
Had to do some searching; all of the indications and "remedies" have been exhausted in your case. So, it comes down to someone missed something somewhere. I know you always point out the "loud click"; this is important to know what is clicking. Is it a relay? Perhaps the relay has bad contacts. Something that wouldn't be checked normally but simply replaced. Is it the starter clicking? I know we've discussed this before as well; it could still be the voltage drop to the starter is too much. But this can only be isolated by measurement when it fails. (Very hard to do in your situation.)
Do you have electronic start? Or a key start? If the click happens in the electronic scenario, again, the starting relay may be defective. If it clicks in the key scenario, perhaps a bad switch.
All of this (related to electrical faults) is going to require measurements to finally find the issue.
Mechanically, I know the starter was replaced and the odds two are doing the same thing is highly unlikely. But if the loud click is the starter, (again we have talked about this) there could be an alignment issue with the starter motor. The fact that you can disconnect the batteries then re-connect and suddenly it starts to work, may be coincidence in the case of a mechanical misalignment.
I feel your pain! I only wish I could be there to help isolate this. It leaves you with no confidence that it will ever be normal without proper identification of the problem and not to "guess" by replacing parts.
I truly wish you luck in getting this isolated, I would seek help from a higher authority than the dealership with the troubles you have had.
Best of luck. :confused:
EDIT: All the P06E9 is saying is that the engine failed to turn over when the voltage was applied to the system via the start attempt.
Oh no! I’m sorry I asked 😬
I think at this point there’s only one logical explanation…
Yesterday was the second time this has happened when my Wife was with me, and she had a couple insights worth sharing.
First, she's mad and wants me to get a new (to me) truck. Ugh.
Second, both times she's been with me the truck was parked on a slight incline.
Lastly, timing wise this seems to happen every 3 to 4 months.
That's interesting because the first time this happened, ever, was in my.old driveway which was a decline. Not sure if there is a there there.
The loud click... It's actually more than one and my title is misleading. There is a loud click coming from under the hood and I've determined that it's the BJB. The other one is from the power inverter under the rear passenger seat. It's been too long for me to recall if the starter clicks at all.
All the voltage testing still makes complete sense to me but ...
1. I'd have to learn how to do it.
2. I'd need another person, IIRC.
3. I'd have to have all the gear with me at all times since it's unpredictable.
When I replaced the BJB, I applied dielectric grease to the two harness fitting on the underside before putting it together. I'm tempted to pull it apart again.
I've done so much to this truck, the idea of starting over is soooooo off-putting.
I hear you loud and clear. When I used to troubleshoot instruments, if I didn't find the problem on the first go-around, it was frustrating to start all over. I could pick another unit and start all over with the same problem but with a renewed outlook. It was different somehow.
So instead of starting over, I would want to look at the overall steps and observations so far and try to determine, what step could have been missed, to equal all of the current observations? (Rhetorical question) All observations are important; however, some may be more important than others.
The incline observation may have some merit, but what would be affected by having the truck at an incline, and could it cause the starter motor to not engage? (Another rhetorical question.) Something to keep in mind for later after eliminating the simple stuff.
I still want to focus on the starting electrical to eliminate that as a possibility. It's the easiest thing to eliminate if you can get someone to make this measurement. I'll explain:
When a starter is requested to engage via an electronic start or a key start, the computer goes through a sequence of actions to cause the starter to engage and does a cross check to see if the result was positive. (checksum =0) In this case, the P06E9 code says that the voltage sequence started but the engine sensor did not detect movement. That's high-end talk for "it didn't start". 😁
Here's what really happens: The ignition was turned to start, the BJB starter relay clicked to send voltage to the starter relay (solenoid) attached to the starter motor, the starter motor should now click (engage) and the motor either did not engage, or it engaged (or attempted to engage) and didn't turn the engine over. Boom: P06E9
So, what would cause this scenario? (Yup, another rhetorical...) The first thought; since it is clicking, voltage is getting to the starter relay in the BJB via the key or electronic start. At this point, I don't know if the voltage is going to the starter motor from the Fuse F40 (via I'll call it K40 relay) contacts. So, a measurement is necessary at this point. One indicator may be the second click is really the starter motor and sound is emanating to the rear making it sound like the inverter, or since the inverter is designed to engage full power on start, and since it didn't start, disabled it. (The inverter will only output full power if the engine is running)
So here is how I would measure this in steps: (Sequential steps will dictate the next step based on result.)
1. Is there 12V at the Violet/Green wire at the starter junction?
a. If there is voltage at the starter, is it 12V? Yes/no
b. If yes, the starter is not engaging. (Starter issue)
c. No, the K40 relay is not engaging the contacts, even though clicking. (Not a likely scenario since the K40 is suspected new with the new BJB) or the voltage is being dropped in the circuit due to a high resistance in the wire or contacts.
d. Is the connector between the starter and the BJB making good contact? It appears there is a connector between the BJB and the starter; has this been checked for contact or corrosion? (Not a rhetorical question.)
e. If the voltage is being dropped via the Violet/Green wire, then there will likely be 12V at the BJB F40 but not at the starter. (High resistance in the path)
There are a number of things I would check past this but I'm not suggesting you have to do this; however, FYI, I would hook a meter up between the starter and the Violet/Green wire coming out of the BJB. This could be a "permanent" hookup with a small panel meter and easy to monitor at all times. Should the start issue appear, you can quickly look at the meter to determine the outcome.
If the meter was to read a voltage during start, it would indicate drop in the wire. (Not good) A high voltage would indicate the wire path is open, a medium or lower voltage would indicate a high current drop in the wire path.
If the drop remained 0 volts (or close to 0) (good) then the starter is simply not engaging. The causes of this gets more complicated and the incline may become important. If the starter is not aligned correctly, it may mechanically be incapable of engaging if there was any flex due to the incline.
However, this is truly a bizarre possibility since the starter is supposed to be attached and torqued to the engine. But not necessarily out of the realm of possibilities.
Again, I would concentrate on the electrical before going any further to eliminate that as the possibility. It's the most logical scenario.
As always, Hope this helps.
For what it's worth (likely nothing) I just got a couple recalls in the Ford app. See below.
Ones for trailer lights (kinda important!) And other is PCM but I believe it's to do with emissions...
Anything computers related or electrical systems can have gremlins anywhere in the chain and sometimes where you'd never think to look.
I know this has been a head scratcher for a long time so I'm not gonna fire a bunch of could be's at ya on it now. But thought I'd share regardless 👍
