Unfortunately most has been tried, I would say hearing the click is a sign that the bcm and ignition are talking and want to make things happen. Being it is so infrequent until it isn't type of thing for the trigger wire at the starter try a new terminal end. It has been fiddled with to the ninth degree. The other thing I would suggest it to load test the wire itself, wires can ohm well but not carry a load for shit imagine a perfect storm hitting then its fine. To load test I would suggest a old school headlight. Wired to a ground and the positive tied to the starter signal wire. And it should shine bright the whole time it is cranking. If it blinks or gets dim then the issuse is the wire or command. You can also test the signal wire through the relay, I would have to check the diagrams on where it is at. While your at it test the main hot wire as well. You want a high amp load to make sure the wire is capable of carrying the current.
Now I have seen in older fords the lead frame in the transmission cause a lot of gremlins and grief. Never on the newer trucks. I did have one a 2017-19 where the range switch in side was bad. Replaced it and no issues. When it happens again place the truck in neutral and give it a go at starting.
My 2020 needed a bcm for a reason I have never seen before and since. My truck would dimly rapid blink the running lights and the throttle body would just acuate back and forth for hours. Turn the key and no communication with anything wouldn't start or unlock the doors with the remote. Only reset was disconnecting and reconnecting the battery. Once that was performed she was happy until she wasn't, and like you no rhyme or reason would make it do it. New battery, nope. New under hood fuse box, nah. I bought a new bcm and had it programmed and haven't had this issue since.
Also a loose pin in a connector at the pcm,bcm or battery fuse box.
I even had a customer with a aquarium for a tail light, causing all sort of grief in unrelated areas. Replaced the light and harness no issues since. Nemo was pissed to be relocated.
I will say sometimes shit just don't want to be fixed, due to all the outside things these newer Sky net vehicles have can cause a ripple in the force.
Sorry I can't be of more help, diaging on the net, over the phone or even in person can be frustrating. Don't throw in the towel yet. There are some brilliant peeps on this forum. Unfortunately a diagnosis for this is time. And time is $$$. Not that you haven't thrown the book at her.
Where are you located at, I'm in Magnolia, north of Houston.
