Installed the small panel in the center console. Note to self, the smaller openings around the edges are NOT big enough for the included screws. I learned this AFTER I had already marked and drilled my holes. I was able to widen the gap and make it work. Glad it worked out, I was worried a bit. Love this addition.
Also installed the rear release kit tonight (I plan on doing some audio stuff eventually so figured might as well put this in now). Install was easy.
@Jericho - I closed it right the first time! Then, reached back to see where the release strap was, pulled up a bit on it to have it reachable, and it released again. So I thought, hey, no problem, closed it easy the first time. Yeah…. Took me 30 damn minutes to close it again, and even when it latched, I’m still not sure what I did right! Haha!
Rear latch kit:
https://www.builtrightind.com/colle...ndustries-ford-f-series-rear-seat-release-kit
Console kit (be sure to add the hardware install kit as well):
https://www.builtrightind.com/colle...ate-10-0-x-7-5-universal-molle-mounting-panel
