Twin Arb Compressor Mount Behind The Rear Seat For 2017+ Superdutys
Right, but the upfitter switch wiring is already tied into the vehicle's electrical system/battery power. I have lights connected to those wires without ever touching the battery.
Lights draw way less power. I'm not sure the upfiter wiring alone can accommodate the load.
If you check out Dirt Church's install instructions (on his site), you'll see that he uses both an upfiter for the switched and a reasonably heavy gauge line to the battery to actually run the compressor.
That is correct.
Hello, Ford Tremor Forum
My name is Troy Rutherford, owner of Dirt Church Industries.
I have been in the automotive, off road and outdoor industry since I was old enough to hold the flashlight while my dad worked out in the garage. Our products are designed to fix problems that exist in the automotive, and outdoor industry.
I have a Lithium Grey 2021 F-350 Long bed with the Carli 2.5" pintop suspension, with the entire catalog thrown at it, sitting on 37" Toyo tires and Method wheels. Currently at 32K miles on the odometer with zero issues to date.
I recently came up with a design that allows you to mount the twin ARB compressor in the cab of your 2017+ Superduty. By relocating the factory bottle jack behind the rear seat it cleared up enough room to mount the compressor and provided a secure mounting location for the compressor. In addition it allowed for additional storage of airlines and other commonly used air tools.
This kit is 100% complete with very detailed installation instructions. 6 gauge duplex marine grade wiring is cut to length, properly crimped terminals, heat shrink tubing installed, 80 Amp fuse breaker, powdercoated 3/16" thick steel brackets, 25 foot airline, fittings, hoses, couplers, 1/4" air line, as well as a hammer lug crimping tool provided that will allow you to crimp the final two terminals on your end.
I look forward to answering any questions you may have and possibly coming up with additional products for the Ford SuperDuty as a need arises.
Product details can be found HERE.
I would be interested in a Group purchase!
Thank you all for the orders
I have shipped out the three of the orders placed yesterday, as promised. The remaining orders will ship out next Tuesday the 23rd.
I replied to my shipment email regarding the notes I put in order. Please check as soon as possible. Thank you. :)
Hey Dirt Church. I had a day off so I took the time to start my install today. Wish I had heard of this last month when I ordered everything. So take me off and move another up on your list. I may be back in the near future.
Started my Dirt Church mount install today. Waiting on a replacement air fitting that was damaged in shipping.
The included Merlin brand air couplers rattle, so I did not install them and have some Milton 'V' style couplers on order.
I opted to place the power wire from the 80 amp thermal circuit breaker in a different orientation as shown in the instruction manual, as it was interfering with the positive side distribution block. Made two little slits in the OEM red cover to form a 'flap', so the cover now sits flush on the battery.
Thanks for the status and pics! Mine is out for delivery so I will potentially start tomorrow depending on the weather (we may get rain)
Nice! I got all the bulky parts of the install done today. Hoping the electrical portion goes more smoothly. I think the self drilling screws for the side seat brackets could be a little longer as there wasn't much thread engagement on mine.
I'm curious - from reading the installation instructions, you're using the ARB supplied in line fuses and then adding an 80amp breaker? Why both? Or did I read it wrong?
That’s correct. The reason is to save on wiring by reusing most of the original ARB harness that has the factory crimped weatherpack ends. No hacking it up is required.
Now, I have no idea whether the fuses would blow before the breaker trips. I would hope the breaker would trip first, but I don’t know the fuse type and the trip curve profile for the breaker.
Noted, only one pump motor could fail in the ARB and not be enough to trip the 80 amp breaker, but would blow one of the two fuses.
Hacking up - I get it. IF this helps anyone this is the connectors are Delphi Metri-pack connectors ARB uses should you need new pins or connectors. I didn't want a splice on two ends if at all to make the run longer and I wasn't sure how I was going to route it so I knew I would de-pin and I needed new pins for my new run of wire.
Also - on my 2020 there is a rubber grommet UNDER the power inverter as an alternate wire route. You just have to remove the two bolts and push pin that holds the tray and inverter in place and cut a little carpet for access. If you have this, you may not need to cut a hole in your floor. You can see the grommet just inside and above the frame rail and there is enough of a recess/gap under the inverter tray to run the wire loom. It may give you some flexibility in your install. Or a route for an airline for an external tank
I bought all this crap a month prior to finding this kit DC made. I would have been much easier had I found this sooner as I have close to the cost of the kit in the ARB bracket, wires, connectors etc. I STILL may be back for the brackets Dirt Church has made.
I finished up all of the electrical portion this evening/tonight. Don't underestimate how long it takes.. it was quite the battle.
My wiring harness was a bit extra long, so I did a different route to the chassis ground/breaker connection than what is in the instructions so I could 'eat up' some of the extra length. I think it turned out perfect.
Tested the ARB compressor and she works! :D Will install Milton 'V' couplers tomorrow and be done with this install. All the hard stuff is done and I'm glad it's over with.
Can't wait for this to arrive so I can start digging in.
Love the ARB so much I already posted my 8 gallon Husky (loud as heck) compressor on Craigslist. This will be my main inflation air source now since I got rid of all my air tools. It is so much quieter, and with it being in the cab with doors shut, it's even better.
When considering this kit I figured that the likelihood of anyone being in the truck when I want to use the compressor is extremely low for my needs. I didn't consider that having it inside the truck will act as another layer of sound isolation for anyone outside the truck...
Raining here today... Figures, since I got the kit last night. :rolleyes: I'll do any prep work I can today and maybe there will be some breaks to at least get the compressor mounting done inside the truck. Yes, I need a larger garage!!
