Featured
- #61
Let's get this show/ordering started.
You can add a push to connect T fitting and run the black nylon line through the grommet (same grommet that comes in the Dirt Church kit) and out the bottom of the truck to your tank.I had my tiwn arb under the seat in my dodge, no issues. Not that loud. I like the idea of being inside the cab especially out of the way like that.
@Dirt Church Ind So you are drilling a hole through the bottom of the truck to route the wires correct? How would you set this up to run a line for an airtank?
Reading the instructions it sounded like it was gonna be a tight fit for just the wires going through there, or are you saying do another grommet?You can add a push to connect T fitting and run the black nylon line through the grommet (same one that comes in the Dirt Church kit) and out the bottom of the truck to your tank.
You could add another grommet or use a leather punch to make an undersized hole in the grommet for the nylon air line. Whatever you find necessary.Reading the instructions it sounded like it was gonna be a tight fit for just the wires going through there, or are you saying do another grommet?
I get real nervous drilling holes and taking plastic stuff apart that has clipsYou could add another grommet or use a leather punch to make an undersized hole in the grommet for the nylon air line. Whatever you find necessary.
I’m trying to figure out the same thing. I was going to do a separate grommet, since the one supplied will not be large enough for both the wires and air line. I just want to make sure nothing will pinch the line where I run it.Reading the instructions it sounded like it was gonna be a tight fit for just the wires going through there, or are you saying do another grommet?
i don't like the idea of drilling more holes through the truck, but i like that setupI’m trying to figure out the same thing. I was going to do a separate grommet, since the one supplied will not be large enough for both the wires and air line. I just want to make sure nothing will pinch the line where I run it.
The only hole that is required to pass the wires through the cab are on step #11. The hole is being drilled through plastic panel under the passenger side rear seat. As for taking plastic bits apart, the only plastic parts removed are the storage bin and the inverter cover. Both are designed to be removed and do not have any "snap" fittings that are a single use fastener, like those found on a door panel.I get real nervous drilling holes and taking plastic stuff apart that has clips![]()
Thanks for your inquiry. There is enough wire length to run the wires through the fire wall. I looked into this path and it is possible, however the time consuming part is tearing your dash apart to allow you enough clearance to pass the wires through.@Dirt Church Ind Would it be possible to run the wiring under the carpet in the cab and exit thru an existing firewall grommet? I assume there's enough length.
Do we have to move the inverter too? Not sure why the inverter cover must be removed. Thanks for the info.The only hole that is required to pass the wires through the cab are on step #11. The hole is being drilled through plastic panel under the passenger side rear seat. As for taking plastic bits apart, the only plastic parts removed are the storage bin and the inverter cover. Both are designed to be removed and do not have any "snap" fittings that are a single use fastener, like those found on a door panel.
Cover removal is just to make access room temporarily:Do we have to move the inverter too? Not sure why the inverter cover must be removed. Thanks for the info.
Order placed!Sorry for the's. The family and I were out of town enjoying summer travels with my two boys.
The current buy in list is sitting at 20 people who have stated they would like to get in on the buy in. This buy in is capped at 18 due to the current supply of laser cut brackets on hand. I will send the discount code to the first 18 people who reached out to me. If any one fails to order I will reach out to the late arrivals.
I am currently waiting on more 6/2 duplex wire so show up from the supplier and the arrival date is 8/22. Once the material arrives I will be able to ship out all 15 remaining orders. I will ship out 3 orders tomorrow.
I was truly expecting the buy in to take a bit longer and thus allow me enough time to build up inventory of purchased parts. However this was not the case. I will ship the orders out on a first come first serve basis. Please include your screen name on your order as that will help me keep track of those of you who have ordered.
Please let me know if you have any questions for me.
I look forward to getting these kits in the hands of the Ford Tremor Forum.
I'm actually working on my compressor right now, so I guess I'll go ahead, as originally planned and mount it in the bed. We're leaving on another trip in a few days. Please give my spot to someone else and thanks for designing this excellent kit. Sorry for committing and then changing my mind. RaspySorry for the's. The family and I were out of town enjoying summer travels with my two boys.
