Featured
- Staff 🛡️
- #21
- Jun 25, 2021
- 11,052
- 20,709
- 22MY F250 Star White Lariat Tremor
- 22MY Winnebago Voyage 2831RB
Thanks for the detailed response and the pictures @Dirt Church IndI just updated the buy in list, If you wish to get your name added to the post please let me know.
To answer the questions above I thought it would be best if I answered all of them in one post with supporting information.
The sound level:
When running the compressor inside the vehicle with all 4 door closed and the windows up the sound decibels are at ~75.5 DB-A. This is the same decibel level as playing your factory radio at a volume of 8-9 depending upon the song being played.
Heat:
These temperatures were taken today with the outside temperature of 90 degrees outside with the truck in full sun. When running the compressor for 30 minutes non stop. The temperature on the back of the seat, closest to the air compressor was 112 degrees. The temperature on the threaded "T" air fitting was 118 degrees. The hottest temperature recorded on the compressor housing was 160 degrees. The 160 degree temperature is burred deep with-in the compressor and is not at potential hazard due to ARB's heat shields and protective shrouds. See attached photos below showing clearance between the compressor and the rear seat.
Duty Cycle:
I have ran this compressor continuous for 2 hours, in the process I aired up (8) 37" tires from 0 PSI to 65 PSI non stop. This was a test to verify the airlines and coupler were up to the task at hand. All the components tested passed with no issues.
Kit Options:
The air hose, fittings, 80 amp relays and other miscellaneous items will not be removed from the kit. I have spend countless hours sourcing parts that have a high quality design and will survive its intended application.
For example I went through 6 different brands of couplers before I selected the units used in this kit, why so many. Well 4 out of 6 of them rattled when mounted in the truck. In your shop you have a specific brand that you know and trust, I do as well, however the Milton brand rattles, the 4-6 little bb's that hold the coupler tight rattle when in a dynamic motion. The couplers I used are universal and accept both the T or I/M series fittings, in addition they don't require you to pull pack on the collar to push in the coupler. If there is one thing I hate it is rattles. I could go down the list of why each specific item was chosen, however each individual component has been tested to provided the best product at the best possible price.
As additional questions come up I will add to this list.
Dirt Church Industries.View attachment 58510View attachment 58509
Please add me to the list as a potential. I will decide if I want to take this route or a bed mount in ~ week.
