Twin Arb Compressor Mount Behind The Rear Seat For 2017+ Superdutys
"NEW PRODUCT"
Flip Flow, Behind The License Plate Air Chuck & Schrader Valve Mount
https://dirtchurchindustries.com/products/flipflow
Is your vehicle is equipped with on-board air? The Flip Flow provides a discreet and convenient spot to connect to your compressor. It installs behind the license plate, keeping it out of sight and easily accessible. For vehicles with airbags, this kit also enables you to mount the airbag’s Schrader valves behind the plate, preserving a clean, factory look.
Using the provided hole saw, installation requires drilling a 1.5" diameter hole to secure the push-to-connect sealed air coupler enclosure. The Flip Flow can be installed on either the front or rear of your Superduty.
Watch the attached YouTube installation video below to help answer any additional questions you may have.
Installation Instructions.
Thanks Troy,
Dirt Church Ind.
Well I simply must have that. Also really appreciate you continually providing niche tools like the hoesaw somebody might not have.
Lets call a spade a spade, new trucks are very expensive and if you are able to afford them, chances are it was by being good at your trade, skill set or through financial discipline. Wasting time running around town sourcing parts is counter productive. I'm fairly certain ~50% of my customers already have a 1.5" hole saw in their garage, however they sell for $7.00 and who couldn't use an extra one.
The way I look at, if you have to visit your local box store to install an item we sold, then we did not offer a 100% turn key kit.
Where does it tie in to the compressor kit lines?
I've tapped into the existing air line with the supplied "T" fitting on the passenger side, then ran the new airline out the rubber grommet that was installed in the compressor kit. I include 15 feet of 1/4" airline so you have plenty of options if you wanted to mount it on the front or the rear of the vehicle.
I finally got around to installing the rear license plate chuck kit. No more daisy chain air hoses to reach trailer tires or the SxS when it's on the trailer. Excellent product from @Dirt Church Ind as always.
Does anyone on this forum have a direct reply from ARB on this issue of excessive heat with the new brushless twin unit? I can see that several have said they were going to inquire directly but I don’t see an answer.
Haven’t read a specific answer or cause, but Dirt Clutch ended up creating a mounting setup for the brushless that goes over the spare to avoid it having the heat behind the seat.
My suggestion would be to avoid the brushless model until a verified fix is available. The improvements aren't groundbreaking.
Good to know. Was about to pull the trigger on one!
I sent a direct customer contact inquiry off their website link to ARB requesting their commentary on this forum’s concern about heat with the “Brushless” twin unit. Given I recently purchased one of these units which is waiting in my garage to be installed, I am hoping they take my inquiry seriously and understand that all we are looking for is accurate honest feedback. If I get a response I will post here.
Well I got a response from ARB on the”Brushless Compressor” Heat question here it is as a direct quote:
“Hello, the brushless compressor does run significant hotter than a standard brushed compressor, this is just a byproduct of running at faster speeds and pushing higher CFMs. When installing it we recommend using a Manifold kit or hose relocation kit to prevent the air hose from melting, we also recommend not mounting directly on any carpeted surfaces and ensure a minimum of 3 inches of clearance around the compressor. “
Based on what they are saying I’m pretty sure confident on moving forward with my install using Dirt Church’s above spare mount with the air tank using a custom bent solid line between the compressor and tank above the spare tire. I see the added CFM of the Brushless model as an advantage if you want to be able to use air tools off your system. Given their comments I wouldn’t mount inside the cab (I’d go Brushed in there). Hope this helps any of you contemplating this modification.
Once I get around to installing my OBA, I'll probably rig up a little Spal fan from a dirt bike radiator to blow on the compressor motors and wire it in to the compressor circuit. Might even use a timer relay so the fan continues to run for a few minutes after the compressor kicks off. Likely unnecessary but easy enough to do and can't hurt.
This kit is 100% complete with very detailed installation instructions. 6 gauge duplex marine grade wiring is cut to length, properly crimped terminals, heat shrink tubing installed, 80 Amp fuse breaker, powdercoated 3/16" thick steel brackets, 25 foot airline, fittings, hoses, couplers, 1/4" air line, as well as a hammer lug crimping tool provided that will allow you to crimp the final two terminals on your end.
Product details can be found HERE.
Looking at this product, actually a local shop recommended it when I called about on-board air install on my 2025 F250 Tremor - he said "There is this cool product by Dirt Church Industries that mounts the compressor behind the rear seat!"
Awesome!
Is there a way to keep the compressor in the cab, but route the air lines to a tank above/in front of the spare?
Where I live, I really cannot air up while the doors or windows are open, so I need the air chuck to be on the exterior. (too many greenhead and horse flies - they will swarm inside the cab of the truck if I let them! I'd rather get eaten alive myself then subject my entire family to that while airing up...)
Ideally, running the brushed twin compressor in the rear seat to an exterior tank, with the rear chuck by the license plate...
If that could be sold as a single kit, I would be very interested!
Awesome!
Thanks for reaching out to us. The quick answer is yes. You could order the behind the seat compressor kit. then "T" off of the kit to the air tank mounting bracket kit, then attach that to the flip up license plate mount.
Links below.
Brushed ARB Behind The Seat Compressor Kit
2.5 Gallon Air Tank Mounitng Bracket
This is the exact same set up I currently run on my personal rig.
Works great as it allows me to run the compressor in clean salt/dirt free environment, I have an air tank for a burst of high pressure air when needed and an external hidden air chuck that serves as a place to inflate my air bags mounted on the rear of the truck.
Let me know if you have any additional questions.
Thanks Troy
Yes, you will relocate your jack mount under the driver side rear seat of the 23+ Superduty's . We include a couple of spacers and fasteners to mount the factory jack bracket to an existing hole in the cab of the truck.
Jump to page 6 of the link below showing the location. The included spacers will clear the additional height of the inverter.
Dirt Church 2023-2025 Installation Instructions
Troy
Is there a photo anywhere or further description of how you fit the jack to the drivers side with the inverter bracket taking up that factor hole? I saw there were spacers in the kit (just purchased the mount kit, not full install kit) but couldn't put together how to use them to clear that bracket. I guess I need to take another look later today. Any help will be much appreciated.
So i figured it out, was able to get the bracket installed with the spacers and hardware included!
