Featured
- #401
I used tape and tightened the first chuck using a stubby box wrench. I could only get about 25 degrees of rotation per turn because of space constraints… and then the fitting broke off. I thought I was well short of “guttentight”, but it’s hard to tell when you’re not feeling the resistance gradually increasing. At 15 twists per 360 degree turn, I got myself into a rhythm…then “pop”, so I have to replace the part. I think I’m going to upgrade to quality DOT fittings for air-brakes while I’m at it, as the push-to-connect stuff always seems to leak.Been away for a couple weeks, but I will echo the above. When first installed, I had a leak at the same spot, so I tightened it more firmly until it became very loose as well. I was only ever going to install the passenger side, so I used the other provided one, but first put several wraps of tape on the threads and only tightened it to the German spec of gutentight. No issues with leaks since. That was back in March '23 I believe.
I have a long, skinny, 2 gallon air tank. If I have time today I’m going to get under the truck to see where it might fit.
When I did the DCI installation I ran a third air-line to the underside of the truck. The plan is to run that to a tank, and from the tank to a manifold which would allow me to run an air horn and fill the airbags individually, as one requires more pressure than the other.
