Twin Arb Compressor Mount Behind The Rear Seat For 2017+ Superdutys
There’s a relay inside of the ARB compressor that can fail in a closed state as well.
Did you dive into this and figure out what happened? Could help another member if they run into this same issue.
Well, I finally had time to dedicate an afternoon to this problem and it turned out that it took about 4 minutes to identify the problem. 🤦‍♂️
Tested the purple wire at the compressor and upfitter was good. Zero when off and 12v+ when on. Which meant the issue was within the compressor.
Realized that the compressor was shooting air out both over pressure valves and neither were ever shutting off.
Ordered two new relays and new pressure switch. Installed one relay, one compressor worked as it should, other didn’t shut off. Installed second relay, both compressors operate correctly again. Did not change the pressure switch.
The only thing I can’t figure now is how both relays got nuked. I’ve also had the two big inline fuses under the truck both go out on my previously. Something in my install seems to be causing a power problem.
Maybe the relays were failing and blew the fuses under the truck? Glad you got it figured out now. Do you have any pics of the disassembly or the new relays?
I didn't take any photos, but it's pretty straight forward. Just remove the bolts on the bottom, pull off the heat shield and they are plugged in right on the back. Two standard looking 4 blade relays. 12v/40a. PN: ARB-180905SP which I got from Summit Racing: https://www.summitracing.com/parts/ARB-180905SP. So nice to have air back!
I recently installed a new Twin ARB compressor with the Dirt Church kit. Install went smooth and instructions were straight forward. Wired to AUX 6 always hot. When flipped on the compressor would cycle on every 30-40 seconds. I checked for air leaks using soapy water and resolved all leaks. It was able to hold pressure for >15 minutes however I noticed only one side of the twin compressor kicks on and air pressure was weak. Replaced a blown 40amp fuse in the ARB wiring but the other compressor still does not kick on (confirmed by placing thumb over air intake on the non working side). I swapped the relays and replaced the relay on non working side but still doesn’t work. Potentially could be a wiring issue as I haven’t take it all apart yet. Any ideas? I’m losing my mind.
In the main harness are two red wires if I remember right. Did you wire both of those directly to the upfitter wire or battery? You should run the red wires directly to the battery, and then on the second harness run the purple wire to the upfitter. Also, because of the draw of the compressors I would have the truck running anyway.
Upfitters 5 and 6 are only rated for 40 amps, less than what the ARB pulls.
In the main harness are two red wires if I remember right. Did you wire both of those directly to the upfitter as well, or did you run those to the battery? You should run the red wires directly to the battery, and then on the second harness run the purple cable to the upfitter.
That’s a great response. Thank you for sharing your knowledge!
Did the Mechanical half of my install today when I got home. Not bad at all honestly. Going to tackle the electrical tomorrow and with any luck and no leaks I’ll be gtg
Just finished up the electrical part and tested it out! Works great! Didn’t notice any leaks yet, but my truck was in the garage so I was running it with the door open and it’s kind of buggy. I’ll pull it out tomorrow and really test it but for now it works as designed. I have the upfitter harness thingy so I just used the hot wire from that to run to the trigger (purple) wire in the compressor no issues at all so tomorrow I’m going to trim it all down and reattach it shorter and cleaner before I put this project to bed. I’ve got to hand it to @Dirt Church Ind for putting together a very comprehensive kit. Took me about 6 hours total to do it but I did everything alone so feeding wires took a little longer.
I honestly feel like this is the best place for a compressor safe and dry inside the cab and available to use anytime. Oh and if anyone cares I hooked this to upfitter #4 since it draws almost no power. Maybe I’ll take some pics tomorrow but I assume most all of you know what it looks like.
Everything is done tucked in and tested. Compressor stays off about 2 mins between cycles so I’m gonna have to look for a tiny air leak somewhere but overall that’s acceptable. Tbh I just popped a cheap harbor freight nozzle on it for testing and I’d bet money that where the air is leaking.
Overall the install went great and I couldn’t be happier with things. Definitely glad to have this for our next trip.
Oh two things to note, the compressor actually has air filters on top not the plugs obviously. And I had to mount the fuse block on my battery because the space they wanted to use in the instructions already had a 50A stick on fuse block that is near identical feeding my DC/DC charger on my camper.
@Dirt Church Ind Troy, not sure how often you visit us over here but I’m going to pose this question to you and the others on this thread.
So i got to test my compressor a little bit today and it’s definitely cycling every 30 seconds or so. I grabbed a bottle of Snoop (soapy water for fancy folks) and sprayed all the connections.
None of the hose contentions leak and the compressor connection is tight as a drum. From the picture however you can see the space between the hose connection and the QD leaks a lot. In fact I could hear it.
So when I assembled this it seemed strange to me to start with. You’re threading a 1/4” NPT nipple into the QD but with a space in between…. NPT threads work because they’re tapered but that mount in between them stops the threads from really locking together (with the taper). The directions say “Firmly tighten this connection”. I thought I did but you’re basically asking for a flat metal to metal seal…. Which doesn’t seem real feasible. I can tighten it more but it felt pretty snug already.
Anyone have this problem or see the same thing I am?
Nope, works as advertised for a year now. I kick mine on once a month, pressures up the system and no leaks so much that flipping on the switch two weeks later doesn’t even cycle the compressor because the system is still full.
Maybe I’ll just go tighten it MOOR….
Yep same here... ~2 years and no issues.
Now, I don't know if this makes a difference, but I created my own process when I installed that QD bracket vs. what was stated in the instructions at the time:
Post in thread 'Twin Arb Compressor Mount Behind The Rear Seat For 2017+ Superdutys' https://www.fordtremor.com/threads/...ar-seat-for-2017-superdutys.11496/post-246170
That connection is a press fit correct? I don’t remember.
Yes but that’s not where it was leaking.. the press fit is perfect.
Well one tightened up and stopped the second one tightened and than rapidly loosened…. Whoops! Off to Amazon….
Mine did the same thing. They crack really easily. Email Troy at Dirt Church and he will send you some replacements via Amazon on his dime. Great customer service.
I actually just called him and he did indeed offer to send me more via Amazon lol. I actually declined and told him I’d just buy them myself since I wanted to pick up some extras too. I got a 10 pack for $12.99 so I could have some spare parts. His customer service is great. I’m gonna try again Saturday when they arrive lol.
Over the years with manufacturing quality control getting worse, I've noticed that you can be putting together sets of things with identical NPT fittings and some go together nicely but others just don't fit right. So I've just gotten into the habit to put a bit of extra sealant on those threads when I'm working with things that can take sealant, such as compressed air. I find that a quality Teflon tape is usually best for compressed air, like blue monster for instance. Just my two cents.
Do you have a tank? My compressor (without tank) will kick on briefly for half second after 2-3 days, attributed to temperature swings. No leaks after pressure testing. @Modman
