Twin Arb Compressor Mount Behind The Rear Seat For 2017+ Superdutys
Last night my wife had the truck running errands and when she started it after leaving the store she said the air compressor turned on and wouldn't shut off, even though the up fitters were not turned on. I had her meet me and I flipped the under hood breaker which thankfully shut it off. This morning I pulled every fuse in the upfitter box and it still would not shut off.
Couple of things:
  1. It's been running great for six months
  2. It's connected to an ignition on upfitter
  3. It won't shut off at all if the breaker is on, even if the upfitter is off, even if the truck isn't even on!
    1. It won't come up to pressure and shut off like normal, it just runs. This issues appeared at the same time the thing had some kind of fault that is allowing it to run with the upfitter off.
So, anyone have a clue as to how or why something that is controlled with an upfitter would suddenly go into a somewhat "hardwired" state where the upfitter seems to be out of the loop? How is this even possible?
Any helpful ideas, suggestions, feedback would be greatly appreciated.
The upfitter relay may be stuck ‘on’ with welded contacts. Try swapping the suspect relay with another one next to it. If the problem still exists, then the ARB pressure switch is bad, or you have a leak somewhere.
I removed all the upfitter relays and fuses and it still didn't shut off...
Not coming up to pressure definitely sounds like an air leak.
Yeah, I need to crawl around and see. Perhaps the pressure switch failed and blew out a line.
sounds like a short from the constant 12V power wire to the switched 12V control wire. Not coming up to pressure suggests an issue with the compressor itself. I would contact ARB.
Thanks, seems most likely since it seems to be bypassing the upfitter box somehow.
I'll investigate a bit more this week once this stupid heat wave in WI passes and report back.
Seems you may have two issues at play, oddly. The truck upfitter circuit not shutting off power to the ARB, and a leaking line air line/bad pressure switch.
I’d check to make sure the other upfitters are able to be switched off.
You may have a chafed purple wire on the ARB side as well where it is somehow shorted to a neighboring +12V wire for the pump motor, thus the upfitter switch is unable to shut it off.
A way to quickly tell if the purple control wire is shorted is disconnect it from the upfitter side and then measure the voltage from chassis ground to the end of the newly disconnected control wire.
If you find it has battery voltage on it, then the issue is now narrowed down to the inside of the ARB, or the harness running along the frame to the compressor.
There’s a relay inside of the ARB compressor that can fail in a closed state as well.
Thanks Bronco! As soon as I can tear into things I'll see what I'm working with and report back!
I wanted to chime in, as I have been busy lately.
I now have ARB compressor kits specifically for the 2023+ Superdutys, as well as the 2021-2023 F-150's. However the parts are still at powdercoating and not actively on our website....give me a few days for them to show up and then they will be listed.
With regards to replacing the OEM screw bottle jack with a 4 ton hydraulic bottle jack. We have a bracket for that. The F-150's have a scissor jack that gets replaced with a bottle jack to make room for the ARB compressor mounting bracket. This mounting bracket will work on the Superdutys as well.
I just created a new listing on the website, please pay attention to the notes as this bottle jack mounting bracket will not work with the Superduty ARB compressor mounting brackets, unless you let me know in advance and I can combine parts from different configurations. By making a custom kit combining different parts, you will not be using the OEM screw bottle jack. You will need to source a 4 ton bottle jack on your end.
2017-2023 Ford F-150 / Raptor / F-250 / F350, Hydraulic Bottle Jack Mounting Bracket
This bracket will not fit the DRW or F-450/550 OEM bottle jacks.
Please let me know if you have any questions.
Thank you,
Troy
Dirt Church Industries
Anyone know who has the best pricing on the twin ARB kit, maybe that offers military/LE discounts? Ready to install behind my seat w/kit already purchased, just need the compressor.
I got mine from @Nick@ApolloOptics , best price I found and I had it the next day!
Thank you,
Troy
View attachment 129757View attachment 129758
View attachment 129760View attachment 129759
So if we arleady have your original ARB kit for 2022 F250 we can use this to mount a bottle jack on left side of current ARB compressor?
The quick answer is no, you would also need the main compressor mounting bracket shifted over to the driver side ~3".
I need to get my hands on a OEM Ford 4 ton hydraulic jack to test fit up. I need to know if it would fit with the kit that you currently have in your truck.
Troy
Thank you all for your patience. The 2023 Super Duty air compressor kits are currently available on our website, HERE .
If your in the market for this kit you will notice that the bottle jack mounting location shown on the installation instructions step #8 has changed spots. Due to interference with the amplifier, the jack is now located behind the driver side rear seat.
We have everything on our website in stock. Please let us know if you have any questions.
Troy
Dirt Church Industries.
Troy
View attachment 130670View attachment 130676View attachment 130677
Love it!!!! And ORDER PLACED! You’re the man Troy!
So, started my install.
Question, what is preferred method to run the wiring?
1) Old instructions. Under carpet to plastic plate under storage box.
2) New instructions. Pull interior trim for access to a spot to drill.
Install is going OK except I missed the part about sliding the bracket under the rear most strip of carpet. So, I trimmed that bit of carpet off. Oops. No-one will know but me. :p
I had no issues running it to the plastic plate. I cut a small X in the carpet to drill my hole in the plastic, then removed the inverter and storage box, and loosened the rear seat to run it under the carpet completely.
I popped the trim, and I split the carpet as well. Run with what you've got.
Troy
Great spot for the fuse breaker, I wish I had put mine there as well. I now where I'll be moving it to when the battery goes.
I pun it there (ish) on my '22, but the tape didn't hold for long. The Loctite tape I have on it now has been solid all summer.
