Twin Arb Compressor Mount Behind The Rear Seat For 2017+ Superdutys
Well, I have the harness work completed and the ARB/bracket assy ready to go on. We have a break in the weather but it is spotty so I am going to hold off. Should be good either tomorrow or Tuesday to proceed with the actual install... :p
Instead of cutting through the truck has anyone just opted to use one of the pass through gaskets already installed in the truck (one in the rear of the cab and one up by the passenger floorboard)?
Typical Michigan weather... Turned into a sunny evening with no rain clouds in sight so I moved the jack and installed the compressor:
Definitely a tight fit getting the two 13mm fasteners back in. I keep all those one time use assembly tools for just such an occasion. Found a short 13mm wrench that worked nicely up until the last few turns:
I'll install the airlines and brackets tomorrow and the wiring if the weather allows...
Since I haven't installed the air fittings and plumbing yet, I'm going to take a different approach which I think I will enjoy more, and wanted to share in case it helps you as well. I ordered a bulkhead passthrough fitting from McMaster (as well as other various fittings), in addition to two ARB quick couplers and dust caps from Northridge4x4. I will install one on each side of the hitch receiver area, like this photo that was posted on this forum:
This will allow me to keep more of a quiet factor by leaving the cab doors/windows shut with the compressor running. It will also allow me to more easily Tee in an air tank under the truck if I ever want one.
Which bulkhead fitting did you order "item number" and from where?
Update: bulkhead passthrough fitting shouldn't be needed. I found a grommet in the back corner of the cab behind the trim that will allow the airline to passthrough. You can see the ARB in the picture, so it's going to be a nice shot to it with a gentle bend radius and won't be pinched behind the trim.
Also, I'm probably just going to install one ARB quick coupler now next to the rear license plate instead of two underneath the truck on the hitch receiver sides. Should be easier to access and less overall fittings. I gotta wait for the ARB coupler to come in to see if the threads are long enough to mount through the license plate area. Initial measurements seems like it 'should' work, but I will wait and test fit the ARB coupler through the spare tire key lock before committing to drilling.
It'll fit.
Perfection! How many extra threads were left over?
Looking at a picture maybe 2. But I might have to loosen it a bit, when I disconnect an air hose I have to give it an extra push to stop leaking. Also added a washer between the plastic and metal part of the bumper to help with this. Someone else on here I believe added the washer between the coupler and the plastic of the bumper. This might have better results but not sure if you can see the washer then. For the few times I use this I'm fine pushing the coupler back in slightly.
Here is the other person's thread, you can see their washer.
Post in thread 'Where will everyone be mounting their new ARB CKMTA12 air compressor from this month's group buy?' https://www.fordtremor.com/threads/...r-from-this-months-group-buy.8759/post-195593
Makes sense, since I noticed there is a void space between the plastic and metal of the bumper.
I had an idea to make a counterbore/hole saw in the metal portion that way the hex nut would only bear against the plastic portion of the bumper.
That is a good idea. Just don't drill it as high as I did, it was a pain to drill from the back side. Plus is just too close visually to the spare key.
I ordered two air couplers, so I was thinking I could put the other one beside of the front passenger side tow hook. There might be enough room for it. Won't know for a few days:
I may 'eventually' splice in an ARB pressure control system and make my own hoses for four-tire inflation/deflation, so having a coupler at the front and rear of truck would be sweet and thus keep the hoses short.
That would be a tight fit there but I'm probably going to add one near the front at some point as well. Would you then do 2 short hoses for the 4 tire? I was still thinking 1 big hose for all 4 but I like the idea of 2 short ones or even just 1 short one and do two inflations.
I just measured with calipers and it's definitely big enough for the fender washer (34mm OD) with at least 1/4" space on either side of that. If you can measure the width of your ARB coupler at the widest point, I could confirm it.
For the hoses, I was thinking of making equal length (whatever is the length required to reach the furthest tire from the respective ARB coupler), and I'd have the ability to hook them all together in series to make a single hose if I ever need it for inflating trailer tires, etc.
I may chop my 50 ft hose into 4 or 6 equal sections giving me some redundancy with all of the extra couplers.
For the hoses, I was thinking of making four equal length 6-7 ft (or whatever is the length required to reach the furthest tire from the respective ARB coupler), and I'd have the ability to hook them all together in series to make a single hose if I ever need it for inflating trailer tires, etc.
I may chop my 50 ft hose into 4 or 6 sections giving me some redundancy with all of the extra couplers.
It's dark out there but I measured 1.633 inches (41.48mm).
It will fit! :D There's more than 43mm available. I don't think it will look too out of place since it's black and will have a dust cover.
I like this idea... Can't wait to see the final result! I am going to try the Dirt church locations inside first and see how they work for me in real life situations. I was always keen on the rear spot near the plate and this is a good integration for the front!
