Twin Arb Compressor Mount Behind The Rear Seat For 2017+ Superdutys
There may be a clearance issue with the JIC to NPT fitting interfering with the bumper mounting point, so I will temporarily tape the JIC fitting to the backside of the front tow hook trim and see if it interferes before drilling the tow hook trim piece.
If it does interfere, there's one more option of choosing the ARB coupler with the NPT fitting on it (no M18 hex nut) and then using a female NPT to 1/4 elbow push lock fitting to affix/sandwich it, and gain some more room. The elbow will act as a nut and hold the ARB coupler on. I will use loctite 577 sealant if the taper of the fitting doesn't engage enough to seal, depending on the thickness of the tow hook trim.
If that 2nd option doesn't work, there 'may' be room for the ARB coupler above the tow hook centerline, as there is plenty of void space behind the trim piece there.
Thank you all for the orders. The remaining 15 orders of the group buy in are shipping out today.
I currently have parts on order at the laser cutter and will have inventory back in stock soon.
Dirt Church Industries
I spent a couple hours under the truck with some long glow rods fishing some paracord inside the frame for when my tubing and fittings arrive from McMaster, I can use it to pull the tubing in easily. It's going to be sweet :D No push to connect fittings will be inside the frame rail.
Where did you bring it up into the cab?
I got the grommet out and drilled an undersized hole in it and here's a photo showing how the tubing will run to the ARB compressor. Nice sweeping curve and seems like the factory had intended this all along.
Did you run the electrical through another grommet? I know the instructions say drill a hole but there's also grommet pass throughs up by the passenger floorboard.
I followed the instructions for the electrical, because the wiring harness is pre-cut for length and I didn't want to chance being too short after I got up to the battery side when all the work was completed.
After lots of checking things out with my borescope, this location is the most likely candidate for drilling and installing the ARB coupler, given the space constraints behind the trim piece.
Had some time and made a bit more progress with a few findings and tips...
I have carpeting which may change a few things vs. the instruction sheet... Or it may be coincidence - not totally certain.
First, when installing the air line to the push to connect fittings I removed the seatbelt bolt and loosened the screw to rotate the bracket as close to parallel with the rear angle of the floor as possible. This made it much easier to make the connection. When rotated back in position it will naturally conform to the shape. I was able to fit a 3/8" wrench behind the quick connect to tighten the screw:
Second, I had to find the drill location in the floor and then cut a couple perpendicular slits in the carpeting. From the pictures it looks as though there is a section already nonexistent in @Dirt Church Ind truck. You can feel where the carpeting goes from thick to thin to find the spot. You can also pull up the carpeting vertically and shine a light from one of the storage container mount studs to see it. I took some pics to try to illustrate the location:
Drilling was easy and the grommet went in without issues:
After removing the storage container and inverter cover I realized it would have been WAY easier to tighten the 13mm bolts for the compressor if I had done this first. It is possible without doing this (see my other post, #123) but there is much better access to them without those items in the way:
Everything is prepped and the wiring is ready to be installed... Maybe tonight or tomorrow for that. Let me know if anyone has any questions!
Finished up the plumbing behind the seat and out of the truck cab.
Got the tubing pulled to the rear of the truck through the frame rail, but when I went to pull tubing through the front frame rail, I ended up about 18" short to finish the tubing install today. 25 ft. wasn't enough; so I ordered another 25 ft. piece. Luckily, the pull rope is still attached.
I like your approach @BroncoHooves and may follow suit. If I end up liking the inside quick connects maybe I'll keep 'em and just add an additional external fitting.
Thank you! I hope it gives people additional ideas for their truck air install.
Definitely! I'm already thinking about employing another inline 1/4" tee to supply the two interior fittings and the other main leg from the compressor fitting for an external...
Finished the wiring today and fired it up. Works awesome and MUCH quieter than I expected!!
Here are a few pics... Recall from my previous post (#152) my interior with carpeting looks different than the install instruction pictures.
After feeding a decent length of wire up from underneath the truck, I fed the purple ARB wire (attached to the connector) back through the slit in the carpeting near the inverter and through the opening I made near the grommet. This is required vs. cutting open the carpeting further:
Plenty of room this way to crimp, heat shrink, tape, etc. I left a bit of purple exposed for future ID if necessary:
Next I attached the main bundle to the feed loop and pulled it through the inverter slit. You can barely see the cuts I had to make in the carpeting:
To reassemble the main connector I made sure the retention tabs were slightly proud on each pin, as recommended. Since the larger wires are fairly stiff I somewhat lined them all up at once and pushed them home. The small black wire is easy to do on it's own. Note I had marked the order prior to disassembly. This isn't crucial but I wanted to get it back together the same way it was originally:
The rest was well documented in the instructions. I changed a few of the wire routing paths. I still have some cleanup/reassembly tomorrow and can take some final pics of how that looks.
I ended up wiring to upfitter #4. #1 has a reverse light already, #2 is a planned front light, #3 possibly for a horn. I am leaving 5&6 open for now... Possibly for power to the box down the road.
Started my install this afternoon as well. A couple of hints thus far. Attaching the bracket and ARB back to the truck using the 13mm would be MUCH easier if you have a ratcheting wrench. Space is very limited there.
The other item that was tight was putting in the air lines in to the push connect on the seatbelt bracket. I had to take the quick connects off and put the air lines into the push to connect and then reinstall the quick connects to the bracket.
Tomorrow I will try to finish, if not, then Saturday morning.
Thank you all for the tips and tricks to assembling the kit. My biggest take away is my truck has the rubber flooring, I see that the carpeted truck don’t have a clear line of sight for routing the wiring. I will update the instructions accordingly.
In addition I liked the bit about tightening the (2) 13mm bolts with the inverter cover removed.
Troy
@Jasoncolorado I found the same thing (see post #152). Removing the inverter cover and storage box first is the pro tip for the bolts.
I thought about removing the fittings too but went with the bracket rotation method.
Nice job on the progress!!
