Featured
- #821
Didn't pay attention..I have a '21 so my DTE works fine.And how many gallons did it take to fill it? The reason I ask is this is posted in Transfer Flow install papers. And I'm about to order the tank and Forscan isn't fixed yet for 23 and 24
Due to the increased capacity of the Transfer Flow replacement fuel system, the vehicle’s “Distance to Empty” (DTE) reading will no longer be accurate. Based on the original capacity and the Transfer Flow tank capacity of 58 gallons, the following are approximate gauge position/gallon readings for the 58-gallon replacement system (may vary depending on gauge and sender tolerances).Gauge Gallons
EMPTY 1.5 gal.
¼ tank 19 gal.
½ tank, 29 gal.
¾ tank, 40 gal.
FULL 58 gal.
That's the same sheet that came with my tank.
