The DIY at your own risk guide to adding Multi Contour Seats (MCS) to your Truck
@Leadmic . Coming from never having them to having them I believe they are worth it.
When I ordered my 16 I was nope don’t want/need them. Then wife got an 18 F150 Platinum. A couple longer drives using MCS I was sold but when I ordered my 20. No way of getting them w/o some stuff that was a definite no. Figured I would look into adding if possible. Fast forward added all all is good.
ZooDad
I have to ask, are you the OG, The Man, The Myth, The Legend, ZooDad from the 6.0Powerstroke ZooDad Mod?
This thread is rowdy, what an undertaking and this looks awesome. Did you guys see the counterweight in the upper seat back that is supposed to help with vibrations? I was looking to get a picture of where that might be located as I think mine has come loose. Nice idea with the pencil for graphite on the zippers.
That’s funny. Yes that’s me but the mod actually came before the 6.0. I made it for my 99 7.3
I owned 3x Powerstroke 6.0 (two super duties and one excursion) and I did that mod to EVERY ONE of them lol. I got really good at it using a 3" hole saw and lining it up perfectly with the S&B intake inlet.
Mods were a whole lot easier back in those days !! Glad I cut my teeth there instead of now.
I did not need to completely remove the seat back cover for the MCS install. I just unzipped the seat back cover high enough to get access to the lumbar frame. Unfortunately, I don't recall seeing any obvious counter weight. Here is a pic of the seat back unzipped. I also just took a quick look in the MY19-22 Service Manual and did not see a counter weight described either. I wonder if its part of the seat restraint guide that the head rest slides into?
@Svenster and I had the parts list from another user on the FTE forums and I had corroborating info from a diff forum with F150 parts. We both reached out to no avail. So with the parts we knew we priced it out and it was pricey. @Svenster went out and found the ebay resource and was able to get the parts from him. I did the same. Richard was awesome he sent all the parts directly to us and it was everything we needed which is listed here. Now those parts are specific for our super duties as that is what they came out of. I then got in contact with @ZooDad who did his truck. So not long as it was all a single vendor.
Good Morning Sir! I have been wanting and doing everything I could do to get this mod since Ford hooked me up with the 300.00 savings. After reading your post about a month ago, I went to Ford and ordered all the parts on your list. I was finally able to pick them up yesterday. As you can imagine I was giddy as well hell! Talk about Christmas Day! The couple of things that I have questions about are: In your pics of the harnesses there is a module that is attached. I received the modules but as a different part number on your list. I believe those modules just happened to be in the pic but wanted to make sure that I am correct. That’s the easier question. My next one is the one that has me a bit confused. Two of the parts on the list (Passenger seat back bladder & pump - FU5Z-14F549-H)(Passenger MC seat module - FU5T-14F549-BH). I circled both of these on the list you provided. The next pic is the parts that came in and they both look like a pump but when I look at the directions it appears that the back and bottom bladders connect to the same pump. Is there something that I am missing. The harness that I sent shows how it came in from Ford but I noticed the pic you have of the harness has the pump connected to it. I assume mine is separate because I ordered the parts from Ford as I had reached out to the parts place you recommended but he never replied and I really want to ensure I was able to get my project done. Thanks so much in advance for your assistance!
@Nikolaiss
The modules are the same, you just got the "H" (latest" calibration (Firmware) saves you from updating them later.
The modules are like manifolds, yet both back and bottom connect to it. The pump is a separate item connected to the seat back bladder assembly. Look at the very first photo, the pump(s) are on the left side in the grey fabric covers.
Hope this helps. Let us know when you are ready for the ForScan changes also.
ZooDad
I will look at my bladder when I get back to the house to ensure the pump is on there. I am sure it is (hoping). I realized last night that I have 2 modules instead of one and I did not get my back bladder. So, I will order that today. Question… Do you know which module I should use out of the 2 (BH or H) on the passenger side? I was wondering if one may have been superseded. Hhhmmm???
So this would work on max recline 2023 platinum seats?
If memory servers me correctly
14F548 is driver side
14F549 is passenger side
ZooDad
ZooDad
I verified and you are correct. Great memory! The thing is I received 2 modules for the passenger side 549-BH & 549-H. Obviously, I will only install one of them but I wonder if/which one is the correct (or maybe updated from Ford). The driver side is 548-BH.
I would use 549-BH and return the H
ZooDad
What was your cost for all these parts from Ford, if you don’t mind me asking.
ZooDad
That is what I was thinking. Especially since the driver’s side is 548-BH. I am also curious about the Forscan update you were referring to earlier. I will be completing this as soon as I get the passenger bladder and pump assy.
Right at 2200.00. I tried to reach out to a few junk yards and could get all the parts and/or was getting the run around. My thoughts going into this purchase was I used all my points from purchasing my truck (roughly 425.00) plus the awesome 300.00 Ford saved me by taking my MCS seats. At the end of the day I will be paying about 1900.00 for these parts.
After I get my feet wet doing mine I would consider doing this for people in the Jacksonville, FL area. Something to think about…
Thank you for the reply. Ford should really be at a minimum selling the parts to the guys that got it deleted for $300.
