I believe the resi is supposed to be at the bottom pointing down. Not sure why but that’s what I read in the instructions (I’m pretty sure that’s were I read it) and it has been discussed on this forum too
You are correct. Everything I read said the same as well. I chose to install it up for additional protection of the resi and the external adjustment screw (now faces the rear of the truck) plus I can get to the adjustment through the wheel well rather than having to get under the truck. It seems to me that the unit will still function the way it should, if I’m wrong, it’s on me.I believe the resi is supposed to be at the bottom pointing down. Not sure why but that’s what I read in the instructions (I’m pretty sure that’s were I read it) and it has been discussed on this forum too
Yeah I cannot imagine why it matters which way the ressi facesYou are correct. Everything I read said the same as well. I chose to install it up for additional protection of the resi and the external adjustment screw (now faces the rear of the truck) plus I can get to the adjustment through the wheel well rather than having to get under the truck. It seems to me that the unit will still function the way it should, if I’m wrong, it’s on me.
I don’t know how much better the ATS is vs OE but I cannot imagine why tell a light difference. It took ad few adjustment and I am probably 2/3 the way to full lock on it but it’s how I like it. I installed it the same time o did the Fox HTO shocks so it’s hard to say what improved the driving feel. But I’m happy with my minor modifications. I think the shocks were a pretty good improvement. The cost of the stabilizer I really don’t know of the juice was worth the squeeze but it’s done nowI have the RC dual stabilizer. I don’t have the ATS setup. I am about over the house of cards game. I would just like this truck to drive and steeer properly.
While I don't have a personal answer for you, this may help. See post #7:Can anyone comment on the Fox ats vs the fox dual stabilizer. I love the look of the ats over the dual. I am going Toyo mts 37’s x12.5 so it will be a heavy tire. Much appreciated.
You're welcome. Based on your response, I would do the Carli hi/low. This will not only be aesthetically pleasing, but function to your liking. Keep us posted, my friend!Thanks Optimus. What’s your opinion? If money wasn’t a factor would you do the Carli hi/low and call it a day? I’m personally not a fan of the Fox duals because they remind me of a Bigfoot truck. Just my preference. But it the Fox duals are truly the best maybe I do it. I just don’t like seeing it from the front either the tremor valence being so short. I’m getting the Fox 2.5 elites so the ats looks like it would match but some previous threads were showing bolts failing early on.
wow. Good find. Fox's website is misleading. If you put in "2023, Ford, SuperDuty" in the find page. It recommends a standard ATS 2.0 part #983-02-143. OR standard TS 2.0 part #985-02-132 and says "Requires drop bracket for greater than 1.5" lift"Just a FYI, I recently purchased the Fox ATS steering stabilizer. It didn't come with a spacer like many have had and had some install issues with the clamp being a much smaller I.D than the drag link.
So I checked Fox's website on my computer to try and trouble shoot. Interestingly, I found a link for instructions for the ATS stabilizer for 23+ Superduty which was a completely different set of instructions than came in the box. The new instructions specifically state that the Tremor package is considered a lifted truck and requires their axle relocation kit. The regular ATS mounting location is for stock height trucks only.
This may be why several have had issues with alignment, bolts, and failure of parts.
It looks like the relocation kit costs 233.00 on sale right now. But a few places had the stabilizer with the relocation kit as a package for 522.00.
Just a heads up for anyone interested and in the market. Here is what the package with the relocation kit looks like.
I completely agree with you. I've had mine on for over a year on my 24 as well. It was installed by a guy that works for Fox and the only added piece that he used was a drop-down mounting bracket to get the shock as close to horizontal as possible.I don’t know if anything changed but when I ordered and installed the ATS on MY24 I didn’t see anything mentioned in the instructions about needing a relocation bracket for the Tremor.
I’ve had mine on for about a year and 30k miles and like it so far
