only 7 left now! That's the best pricing i've seen so far. I've been watching this for awhile and finally pulled the trigger.
Did you add the Fox stabilizer with the shims? If so, how is it?Thank you. I have the Carli casters coming. Will this work well with them?
Sir. I did not. RC replaced the failed shock and I had it installed. I did order and install an RC adjustable track bar. That seemed to have helped along with an alignment.Did you add the Fox stabilizer with the shims? If so, how is it?
The middle is exactly where you want to be and tighter of course!Just curious how you have your ATS set. Just put mine on. I’m literally in the middle. Do you guys like it tighter or looser? I haven’t played with it much yet and since I’m just driving around the streets and not the dirt I’m not sure what direction to adjust it
are you sure your not a little to the “left”Well...the middle is exactly where you want to be and ummm, that's all I'm allowed to say at this time.
You're "right" about that!are you sure your not a little to the “left”![]()
I installed mine on the ground with no issues. I did have my son hold the steering wheel at full lock while I was adjusting it to ensure it would clear both directions. If you turn the wheel to full lock and let go, it backs off a little which is why I had him hold it while I was under the truck.I have seen some posts about bolts breaking is there any consensus as to whether this is due to installing on the ground vs on a lift? I have 37” recon grapplers and the steering doesn’t feel so good so looking at the Fox ATS.
2024 Lariat Ultimate Tremor 7.3 6k miles. Method 18x9 +18 / 37x12.5 Nitto Ridge Grapplers.
Pm sent, I just listed one in the classifieds on Friday if your interestedI have seen some posts about bolts breaking is there any consensus as to whether this is due to installing on the ground vs on a lift? I have 37” recon grapplers and the steering doesn’t feel so good so looking at the Fox ATS.
Does anyone have a link for the drop installation bracket to be used because of my 2.5 inch lift?
Thank you for sharing this, it looks really nice! But really pricey!![]()
Steady Track Steering Stabilizer Kit, 2-6" Lift, 2017+ F-250 & F-350
Improve steering control and reduce bump steer on your 2017+ Ford F-250/F-350 with S&B’s Steady Track Steering Stabilizer Kit for 2–6" lifts. Part #105101sbfilters.com
After searching the internet for the past 24 hours and several phone calls, I have found the drop bracket for the ATS with 2.5+ in ch lift!! Hopefully this will be helpful and save you some time if you are ever looking for this part.Has anyone successfully installed this Fox ATS without a drop bracket that also has a 2.5 inch lift? I am having extreme trouble finding a simple drop bracket. Thank you in advance
Just a quick update. Here are the after installation pictures of the Fox ATS steering stabilizer using Wicked Trucks drop bracket. Everything mounted up perfectly as it shouldAfter searching the internet for the past 24 hours and several phone calls, I have found the drop bracket for the ATS with 2.5+ in ch lift!! Hopefully this will be helpful and save you some time if you are ever looking for this part.
https://www.wickedtrucks.com/2011-current-f-250-350-factory-steering-stabilizer-drop-bracket/p2207
Did you install an adjustable track bar? I am at my wits end with this stuff. I had an RC adjustable track bar installed, and now something is popping. I live near Knoxville and I cannot seem to find anyone who can help me properly. Each place I take it to it seems as though they make shit worse. I may just take it all off and go back to stock. If anyone lives near Knoxville and knows of a place, that is not Line X and that knows big truck suspensions and what tondo I would appreciate the referral!!Just a quick update. Here are the after installation pictures of the Fox ATS steering stabilizer using Wicked Trucks drop bracket. Everything mounted up perfectly as it should View attachment 209700View attachment 209701
I’m still running the stock track bar , my kit came with the track bar relocation bracket so there was no need for the adjustable TB. Hopefully you will find whatever is making the popping, nothing worse than chasing down phantom noises.Did you install an adjustable track bar? I am at my wits end with this stuff. I had an RC adjustable track bar installed, and now something is popping. I live near Knoxville and I cannot seem to find anyone who can help me properly. Each place I take it to it seems as though they make shit worse. I may just take it all off and go back to stock. If anyone lives near Knoxville and knows of a place, that is not Line X and that knows big truck suspensions and what tondo I would appreciate the referral!!
