Review : Fox ATS 2.0 steering stabilizer
Anyone have thoughts on this vs the Carli high mount stabilizer?
The stock stabilizer is not sufficient for the 35" tires. As the Duratracs wear, this will worsen. I am talking about just on road driving.
Value is something only you can determine yourself, for your needs.
Mine wonders enough on pavement for me to say not only is there value, but almost necessary.
Thanks Soulezoo. I had (mistakenly) assumed Ford put a beefier stabilizer in the Tremors. This is very valuable insight since I have almost zero wheel time in a Tremor and my 2022MY is months out.
My truck: 2021 F250 Tremor w/ 6.7 - stock suspension
Had it installed today (I have a shop adjacent to my work, and the guys threw it on for me real quick. No specific tips on installation, other than they said it was as straightforward as it gets)...
Had a 25 mile drive home from work (75% hwy), and then some around town drive after I got home. Initial thoughts are it’s worth the money. That squishy feel, especially around turns, seems to be gone, and overall the steering feels crisper. I feel like I have to correct the wheel far less than before to stay centered in the lane. I hit some expansion joints, RR tracks and intentionally hit some manhole covers that I usually specifically avoid on my way home, and the front end and steering wheel felt far tamer than usual. I initially set it at 10 clicks, then bumped it to 13. I may play around with it a little more, but this will be added to my list of must haves as long as I own a super duty. Now, if I could only get the unloaded rear end to simmer down! LOL....
Great feedback! Glad to hear the stabilizer provided some very noticeable, instant benefits on a stock Tremor.
Just my thoughts, I have no empirical evidence or direct experience (full disclosure, I have the Carli lower with diff guard)...
I think if you're stock, the Fox ATS provides the best solution. One shock and done.
Carli designs theirs so the optimum is both lower and upper and you can specifically tune them to correct pulling issues (many tires can exhibit pull one way or another having nothing to do with alignment or parts wear). Especially with 35" and above tires. So if I were running big (37"+) Toyos or Nittos (notoriously heavy tires), and off road a lot, I'd definitely go Carli. Everything else I am certain the Fox will be great. Past experience with big tires off road has shown me that one is not enough no matter how stout the shock.
I used to have a built full size (OJ) Bronco with 38's. I forgot the brand, but it was two huge yellow stabilizers to calm that front end. One was no where near enough.
I am going to add this for general edification...
Someone is likely to wonder why I am getting the Fox on the group buy as opposed to just finishing out with the Carli high mount (since I already have the lower)...
First, with the group buy it's about $45 cheaper, it appears easier to install, and I like the adjustments that are just clicks. With the Carli, you have to have access to nitrogen to make adjustments and if you're doing it yourself it's hit or miss. I like just turning the knob to adjust like my old Rancho shocks. Finally, it helps this forum.
That’s some fantastic context! And makes a ton of sense to me.
The need for nitrogen to adjust the Carli is a great callout, too. Basically requires a shop to do the adjustment for most people.
The PMF dual stabilizer was just delivered to my house and now I’m debating on whether I should put that on or order this stabilizer now that it is part of our group buy. Any thoughts on a comparison is very much appreciated!
I ordered this...just came Friday. Fox part number 983-02-143. It has a short eyelet spacer and a long one. See pics. I thought this was a mistake so I called Fox and he said that the long spacer is new, and they came out with it specifically to work with stock AND leveled trucks. I am installing tomorrow, but my truck is stock. Will share performance results after install.
So which spacer did you use? Carli says there 3.5'' lift only raises the Tremor 1.5'' that being said it is lifted but still stock.
My Carli Front Sway Bar and Links are still on backorder. Has anyone here installed the Sway Bar and links?
Do you see a bid difference while street and off-road driving?
Thank you
Oops 985-24-001
Just a heads up of my experience going through trying to decide what SS To go with. I have the 2.5” ready lift also and 37” ridge grapplers. Was def getting some wander and what seemed like way too much road feedback in the steering. Was about to order the ats and called fox to double check on the compatibility with 2.5” level. They said it was a no go and would require a drop bracket to correct the angle. They are currently working on it and approx 3 months away from rolling them out. I wasn’t looking to wait and asked about the ifp 2.0 and was told it would fit and work perfect. It was the part #985-45-001 mentioned above. Installed today, super easy 20 minutes. Drove very farmiliar route home from work and the difference was huge. Actually the first SS I’ve changed out and had no idea how big the impact would be. Got to give it some time but I give it 2 ??S up. Looks like there’s quite a few guys running the ats and super happy, I don’t know if they are lifted or leveled though. Could be fox just being over cautious also. Just my 2 cents
Installed the stabilizer today (985-24-001). Night and day difference on the road with it on after throwing 37's on. Love it! Thanks for the review.
This will be the first mod I do to my 2022 Tremor (when it arrives)... does anyone know if it will fit the 2022's? Thanks
Yes. No difference from 2020-2022. (And before)
I came to the same thoughts...
Stock Tremor ATS or King Stabilizer
Lift and bigger tires then Carli
But I also am thinking that the Carli Track Bar AND the Fox ATS may just be my combo
https://carlisuspension.com/product...ents/2017-plus/ford-2017-adjustable-trackbar/
Did yours come with the relocation extension shaft or did you purchase it separately? I have mine coming tomorrow to put on my stock Tremor 2022 but it doesn't say anything about the extension coming with it.
Reviving this thread to see if anybody has a long term review. Do you still have it installed? Still enjoying it? I'm seeing it's $100 off at some retailers so considering yet another upgrade to my stock tremor.
Which retailers and I am trying to dial my setup in. Ty
I just got mine from Amazon today for $360… Hurry, there’s “only 10 left”! 😂
Cheapest its been in 4 years on Amazon. Looks like recent reviews discuss the bolt breaking issues that many have noted on here. Wondering if this comes with the early bolts.
For price history on anything amazon, use camelcamelcamel.com
