Review : Fox ATS 2.0 steering stabilizer
If your stock steering stabilizer works fine with the 2.5 Ready Lift than the Fox ATS should work just fine too.
If you look closely at this pic you can see the through hole to the right of the clamp where the stock stabilizer was mounted. Not much difference with the clamp.
I ordered mine from PMF and it should be here next week. Looking forward to getting it installed to see the difference. I just have the 2 lowers now no upper due to a different bar from Kelderman.
I haven't had a chance to mess around with different dampening settings yet. Everything I read prior to getting mine said there is 25 clicks of adjustment. I counted 30 clicks, so they may have made an improvement to the adjustable range. I set mine in the middle at 15 clicks and it feels great. I may try to add a little more (another 5 clicks) because I like tight steering, as long as its not a struggle to return to center when turning. I like the BMW stiff steering feel.
Does anyone know if the Tremors came with a factory upgraded steering stabilizer?
Not that I have seen.
I get my new rear swaybar, Fox upper steering stabilizer, PMF drag link, ajustable tie rod ends, and rear drop sway bar links installed next Wednesday.
This Saturday I will have my undercoating, sound deadening, and rust protection installed $599.00 installed by Ziebart in CorpusChristi the only place I can find in Texas to install undercoating.
I have been waiting for the past 10 weeks to get the Carli front swaybar and links, it's still on back order.
I also ordered the new 60 gal S and B fuel tank 6 weeks back order, and the Carli Full Progressive Leaf Springs 8 to 10 weeks back ordered.
I will post pictures and give all of you my opinion on what I think of these mods.
I purchased and installed the
Fox 985-24-001 Performance Series Smooth Body IFP Stabilizer from Amazon​
on my 2020 Tremor. Was an easy install. Direct replacement to OEM (although Fox Tech Support would not confirm this prior to buying it - "It should work" was all I got) .
I don't do a lot of off-roading so the ATS was a bit of overkill for me, was looking to just stop the wandering on the highway and this one does the trick!
Just curious - where did you purchase the sway bar from? I'm about to order one.
I am still waiting for mine. I have been waiting since Oct 20. They are on back order and have very little man power since this Covid shit.
I'm just about ready to order the Fox ATS and my Tremor has a Ready Lift 2.5" leveling kit. Will I still be using that same unit that you have listed? Thanks a bunch, Mike
Just a heads up of my experience going through trying to decide what SS To go with. I have the 2.5” ready lift also and 37” ridge grapplers. Was def getting some wander and what seemed like way too much road feedback in the steering. Was about to order the ats and called fox to double check on the compatibility with 2.5” level. They said it was a no go and would require a drop bracket to correct the angle. They are currently working on it and approx 3 months away from rolling them out. I wasn’t looking to wait and asked about the ifp 2.0 and was told it would fit and work perfect. It was the part #985-45-001 mentioned above. Installed today, super easy 20 minutes. Drove very farmiliar route home from work and the difference was huge. Actually the first SS I’ve changed out and had no idea how big the impact would be. Got to give it some time but I give it 2 ??S up. Looks like there’s quite a few guys running the ats and super happy, I don’t know if they are lifted or leveled though. Could be fox just being over cautious also. Just my 2 cents
Oops 985-24-001
That's the number I looked up
All the feedback in this thread is appreciated. I just ordered the Fox 985-24-001 to reduce the chance I will ever suffer a death wobble with 35’s
After having the Fox SS on for a few months what do you think? I was researching the FOX 985-24-001 steering stabilizer and noticed that Fox doesn't list this part # to be compatible with the 2020s. Any idea why?
It's only showing to work with model years up to 2016?
This was posted approx three months ago. Has Fox rolled out the bracket? If so, will it come with the ATS or will it need to be ordered ?
I ordered this...just came Friday. Fox part number 983-02-143. It has a short eyelet spacer and a long one. See pics. I thought this was a mistake so I called Fox and he said that the long spacer is new, and they came out with it specifically to work with stock AND leveled trucks. I am installing tomorrow, but my truck is stock. Will share performance results after install.
Awesome! Thanks for posting the update and any tips on the installation would be appreciated.
Thanks guys! So to be clear, #983-02-143, as is subject of this months group buy, should come with that long spacer so the stabilizer can be made compatible with either a stock or lifted truck?
I'm debating getting in on the group buy - however I'm not planning on lifting my truck nor running larger tires in the short term. I'm hoping to wear through the stock Duratracs before upgrading tires and possibly suspension - though I don't have my Tremor yet to confirm off road feel.
Can anyone tell me if there is substantial value in running the Fox ATS Stabilizer with stock tires and suspension? Or is the factory steel monotube stabilizer sufficient for stock?
For reference, I do spend considerable time off road.
The stock stabilizer is not sufficient for the 35" tires. As the Duratracs wear, this will worsen. I am talking about just on road driving.
Value is something only you can determine yourself, for your needs.
Mine wonders enough on pavement for me to say not only is there value, but almost necessary.
My truck: 2021 F250 Tremor w/ 6.7 - stock suspension
Had it installed today (I have a shop adjacent to my work, and the guys threw it on for me real quick. No specific tips on installation, other than they said it was as straightforward as it gets)...
Had a 25 mile drive home from work (75% hwy), and then some around town drive after I got home. Initial thoughts are it’s worth the money. That squishy feel, especially around turns, seems to be gone, and overall the steering feels crisper. I feel like I have to correct the wheel far less than before to stay centered in the lane. I hit some expansion joints, RR tracks and intentionally hit some manhole covers that I usually specifically avoid on my way home, and the front end and steering wheel felt far tamer than usual. I initially set it at 10 clicks, then bumped it to 13. I may play around with it a little more, but this will be added to my list of must haves as long as I own a super duty. Now, if I could only get the unloaded rear end to simmer down! LOL....
