I have received a recall notice through FordPass. I have not received a recall letter in the mail yet. My truck was built 10/29/20.Have we heard of any Tremor owners receiving a recall notice?
I have the recall notice for my truck, but won't take it in until parts are available and on hand.Have we heard of any Tremor owners receiving a recall notice?
Did you use a feeler gauge to see if the axle tube is crushed? What were the results?I have the recall notice for my truck, but won't take it in until parts are available and on hand.
Same. I still haven't got my windshield recall taken care of after the dealer f'd that situation up for me. I just don't have time to give my truck to somebody for a couple days especially without a loaner. I might try to find the time soon though since all the passes on my windshield expire at the end of August lol.I have the recall notice for my truck, but won't take it in until parts are available and on hand.
Make sure they have a windshield as a replacement. I was out of a truck for a week and a half because they failed to order one before attempting to pull my windshield. Now I will make them have parts on hand before any repairs are attempted. I don't mind them having my truck for a day or two during the week as I work from home, but on weekends I need a truck. The recall for that one only took a few hours.Same. I still haven't got my windshield recall taken care of after the dealer f'd that situation up for me. I just don't have time to give my truck to somebody for a couple days especially without a loaner. I might try to find the time soon though since all the passes on my windshield expire at the end of August lol.
I haven't used a gauge to check, just a visual inspection. It looks like the passenger side has a gap and the driver side block that sits above the spring seat is moving around. Will check with feeler gauge this weekend to see if the right side is greater than .0002.Did you use a feeler gauge to see if the axle tube is crushed? What were the results?
Same except mine was built February 2021I have received a recall notice through FordPass. I have not received a recall letter in the mail yet. My truck was built 10/29/20.
Ford and the other truck producers are definitely in uncharted territory with the ultra high torque competition they are in with each other in these traditionally lighter duty trucks. Engineering of all components and material requirements are more critical than every. My guess is Dana is having trouble getting a supply of materials and are having to source from new suppliers to meet demand. This is the most likely reason for substandard materials getting into the production process. Cost cutting efforts also play a big roll in this as well. It's critical that buyers understand how important supplier integrity and material validation is for final product consistency.We should just have them turn the TQ numbers down to gasser levels and give us back the premium we paid...
I just setup an appointment at Mac Haik Ford in Georgetown, TX. They said the earliest appointment is November 1. Also, they said Ford is not covering loaners for this repair and to expect to be without the truck for 3-4 days.I received the recall notice in my Ford Pass App as well. The actual recall said notices will start to be mailed the week of August 16th.
I doubt this is the case, but I wonder if the weld repair is indeed temporary and the recall will be further modified once there are axles available for the over 30,000 affected trucks. It would be a hell of a black eye to put more than 30,000 trucks out of service while DANA can fix their problem and renew stock. If this truly is a change that DANA made without notifying Ford, these repairs should be at DANA's cost, not Ford's. If DANA was my subcontractor / supplier and supplied a part of service that was not approved (especially if it differs with what they told me they were going to supply) I wouldwantdemand them to replace them with correct part. However grounding 30,000+ Ford trucks would appear to be Ford's problem to the average person - even though it sounds like a DANA problem.
I plan on regularly checking on mine and holding off on the weld repair for now. I would really like to see some pictures of shop welded repairs to see how the welds look.
I just setup an appointment at Mac Haik Ford in Georgetown, TX. They said the earliest appointment is November 1. Also, they said Ford is not covering loaners for this repair and to expect to be without the truck for 3-4 days.![]()
I think you hit the nail on the head.My new truck has yet to pull or carry a heavy load. I have measured the OD of my F350 7.3 axle and the OD is about .075 more horizontally between the U-bolts than it is in the space between the inside u-bolt and the differential. The compression force of the u-bolts has squeezed my axle by about .035". I don't see that as overly concerning but it proves the u-bolts are exerting enough force to deform the axle, and if the axle tube is thin in this area it would cause a problem. Unfortunately I'm in the wait and see camp. Also just for reference the axle tube's OD should measure 4.035", +/- due to paint thickness. This is my axle diameter at all unaffected areas.
Again I want to repeat what I and some others have said regarding the total problem. The axils are being crushed or deformed, most likely by the force of the torque applied to the U-bolts at the factory. This is because the wall thickness is inconsistent in this batch of axles.
The second and more serious problem is the extreme torque produced by the 6.7 engine is sufficient enough to cause enough counter-twist in the axle under heavy pulling load to cause the welds at the spring mounts to fracture or even tear the axle tube wall causing oil to leak. The longer this goes on the more deformed the axle gets and the more the welds or axle fracture and pull apart creating a gap at the front and rear of the spring bracket.
Might not be a good idea if Ford is checking for signs that the damage was intentional. But I am not skilled in the use of the referenced equipment so I don't know how hard (or wise) it would be to try and create a failure "on the bench".Sledge hammer and a domed autobody dolly should make it look like a legit damage. You can thank me now for the idea, but realize the replacement axles are backordered
T'was a jokeMight not be a good idea if Ford is checking for signs that the damage was intentional. But I am not skilled in the use of the referenced equipment so I don't know how hard (or wise) it would be to try and create a failure "on the bench".
Not sure how they can exclude people from a recall where they know they have a problem with a sub-standard part. I am running 37s, but I also removed the massive 3.5” rear block and replaced them with progressive leaf springs to minimize axle wrap when towing.Here's one more thought for those with 6.7 engines. If you decide you need to install larger tires such as 37's or even larger, that will increase the torsional stress applied to the spring mounting brackets on the rear axle when accelerating under high loads. I would highly advise against doing things that could eventually cut you out of warranty coverage related to the axle recall issues.
Where did you get the progressive leafs from? Carli or somewhere else?Not sure how they can exclude people from a recall where they know they have a problem with a sub-standard part. I am running 37s, but I also removed the massive 3.5” rear block and replaced them with progressive leaf springs to minimize axle wrap when towing.
