Rear axle weld issue recall ?
It sounds like a max load and max torque failure from my interpretation. Since the 7.3 has more load, but less torque, no failures have been reported. F250s have less payload and hauling, even though not by much, but I guess no F250s have failed yet. Also, at the plant, everything is in ‘bins’. Could be the thin wall design axels only went into the F350 bin, not the F250 bin. Who knows. I assume if several F250 or 7.3 failures occur, they will expand this. Anyone who knows how recalls work, it is based on liability costs vs recall costs. If projected liability is more, they recall. If recall costs more, they TSB and pay out future lawsuits. Learned this in my statistics class.
So, can anyone calculate the amount of force generated from the U bolts driving the spring purch into the axle tube? The bolts are 14-1.5mm, I think, and are torqued to 185 lb/ft. I would say that the bolt tension is more likely to generate the amount of pressure to crush the tube than any weight in the truck.
Using this calculator I get approximately 15,000# of bolt tension each. With 4 bolts you would have to put 120,000# of weight in the back of the truck to get the same crush pressure on the axle tube that the bolts generate. So if my numbers are right making the argument that the truck was overloaded and that is what caused the axle deformation, is just stupid.
Wouldn’t you need to add the static load of the bolt tension to the dynamic load of the payload to get the overall load on the axle?
What I am saying is that the amount of pressure required to crush the axle tube in this way is being provided by the tension of the bolts not the payload. Yes, payload would provide an additional force, but it pales in comparison to the force provided by the bolts. Also excessive payload would not result in the axle being deformed in this way. Excessive payload would tend to bend the housing along it's length and not in this one particular area.
When I first saw the video which showed the bent axle tube, I immediately thought that they probably had a machine that was over-tourqueing the bolts. However they say that the cause is the wrong tubes were used with reduced wall thickness.
Did you see it written somewhere that they used the wrong size tube? I’d like to know, because if so, I’ll be demanding to wait for a new axle from Ford instead of a bandaid fix.
On a side note, my truck went to the shop this morning and they confirmed what I found, my spring seats were within the. 002 limit on the feeler gauge, so they are ordering parts to do the weld. I’m contemplating not having the weld done, and waiting for the new axles to come in, so we can see how Ford fixed the new axles. I can use a micrometer to measure inside and outside diameter of a replacement tube, and then compare it to my current tube. Also, I can see if Ford just decides to weld the brackets at the factory.
Yes, in this video, it says he goes over the recall notice. Review the content. If you have the .002 gap then your axle will be replaced. If you have no gap, then you get the weld fix. Read the section called "Description of Remedy".
I thought it was the other way around. If you have the gap you get the weld. No gap and you get the new axle.
No. If the gap is .002 or bigger then the axle gets replaced. If no gap, then welderup.
OK, after seeing the second video of the Ford fix procedure, I think I know the issue.
During acceleration, the axle has a moment along it's length that is equal and opposite the force being placed to the tires. It can also have a rocking moment due to the pinion gear. This is what causes axle wrap and wheel hop.
The spring seat and U bolts are what transfer this torsional load to the chassis through the leaf springs.
Given the .002" gap is a sign of failure, the spring seat is twisting on top of the axle housing, pulling one side (or both) of the spring seat away from the axle. This would indicate permanent yielding in the weld, axle housing, or both, compromising structural integrity, especially for fatigue and fracture resistance.
The 6.7L can output much more torque, this can push this harder, thus it is the primary failure powertrain. The F350 is obviously due to the higher loading potential.
I would not expect the 7.3L to be immune to failures, and my worry is that they will not show themselves until after warranty is done. While that would not indemnify Ford, it might make it more difficult to get a fix. But, I think the prevalence of failures will me primarily the 6.7L and on trucks that can create a high torsional load on the axle (high loads).
It may be that on the Tremor, there is enough compliance in the rear axle to not damage these components.
For me, it will be a monitor and wait. I don't push this rig hard, so I don't think it will be a problem for me.
I could easily be wrong, but the impression I got is that the wall thickness is inconsistent, which means the outside edge of the tube - where you can get a micrometer - could be the same, but further in it could be more thin.
So this then is a towing/acceleration force issue rather than a static payload issue?
Guys towing big 5ers and TTs at/near max rather than say heavy truck campers, for example.
After further reading of the NHTSA report, I realized that replacement axle’s will be constant wall thickness. I’m going to put faith in Ford to follow this report and not replace an axle with a welded one w/ variable thickness.
Tonight I wrote a letter to the service manager of my dealership, explaining that for my family’s safety, I won’t accept the weld as an adequate repair, and I would like a new axle put in my $85,000 truck when parts become available.
On another site a guy posted some pics of his brand new 2022 7.3 axle and it was one of these welded up repaired thin wall axles. Guess we know how Ford is going to get rid of this pile of bad axles now. 🙄
I think it is a torsional load issue, which would occur when you put a high amount of torque on the axle.
Perhaps it could also be due to high static payloads (you'd have to know the specifics and run an FEA to verify), but these high payloads are coincident with the high wheel torque when driving/towing. But, given the 7.3 has a higher payload than an otherwise identical diesel, it leads me to suspect it is the wheel torque twisting the spring seat, otherwise we would see the 7.3L included.
To that end, I do not think it will matter whether the payload is a 5er or a truck camper, though towing would create a higher probability of high wheel torque due to the higher GVW.
So far I have not seen or heard of a Tremor that has this Axle problem. I'm not saying there are none, just haven't heard of any. If you have any evidence of a Tremor with the damaged axle, please post it.
I think there may be a few things going in favor of trucks with the Tremor badge.
Our trucks are not the same as a run of the mill 6.7 F350. The vast majority of F350 6.7 trucks coming off the line will have a different differential in them with 3.55 gears and no locker. I could envision a scenario where Dana Spicer would have different lines of production where not all M275 axles are even made in the same country.
I suspect that there is something on the ID tag that will tell us if the tube is thin or thick. I just haven't figured out how to decipher it yet.
To further this discussion I wonder if the different shocks and no sway bar would lead to the suspension soaking up some of the torque.
As well the locker is standard in all the FX4’s and that’s got to be the most common package added to SD’s.
We’ve seen some Tremors hooked to some serious loads, I’m staying positive but I’ll continue to monitor my axel housing.
