Rear axle weld issue recall ?
I'm not an ME but intuitively Ford's fix makes sense.
That said wouldn't it be nice if we as consumers were allowed to
know how many trucks had these suspect axles? It makes no sense that Ford requires a visual inspection. Surely every truck
within a time frame had the under-spec axle so WTF? If every one didn't then that raises more troubling questions of QC to me.
I'll bet you that if the 'fix' does work then Ford will start making
all axles lighter to save money.
fully welding the spring perch was fords only option ,aside from replacing the entire housing ,fitted with thicker wall tubing. so , its not that their fix made sense , it was their only option. but its still a .188" wall tube , whether fully welded or not.
i think your on the right track in thinking every truck in the recall time from has the thin wall tubes , although some trucks arent included in the recall. ford , by some sort of test i suppose , determined the gas versions , if used within normal gvwr range ,dont put enough strain on the axle to deform it.
i suspect however that theres very little failure safety margin beyond advertised gvwr with the nonrecalled trucks.
Take a set of calipers and go measure your axle tube. Do it right next to the U-bolts. Measure it from top to bottom (vertical) and from front to back (horizontal). This will tell you how much deformation there is already. This is mainly due to the torque of the U-bolts. Mine is over 1/8" !
The weld is only going to make it worse. The weld will further deform the tube. All the welding on the axle is done PRIOR to machining to allow for the warping of the tube and insure that the bearings are in line when it is complete. Welding on the tube after the machining, as the recall is dictating, is completely wrong and goes against good manufacturing processes.
Got mine back from being welded. They did not replace the u bolts if they even removed them. Not the worst welds I’ve ever seen and far from the best.
Edit:
Spray painting is so bad I almost thought I did it for a minute. 😂
Missing paint is pretty standard and not necessarily an indication of failure. Here’s a shot of my axle before I drove off the dealer lot. It’s also a 2022 7.3, so well out of the recall window.
so it looks like they just do the weld now?
at 15:10 this video shows them cutting the deformed one they measure and its 3mm (i think) thinner than the correct tube. So is this no longer an issue on a 22?
Edit:
View attachment 47889View attachment 47890View attachment 47891
Oooooh…. Ummm….. Huh!
The most important part of a good weld is clean metal, as in bare and shiny. Certainly the reason Ford specifies removing the bolts is to have clear access to prep the metal properly. It is evident the welds stuck best only where they could get in there and brush or sand it clean. Personally, I would not accept those welds. They are poor quality at best. ☹️
In all reality, if it weren’t for the issue of needing to clean the weld joint well, it would probably be best to weld it with everything still bolted up tight, or at least tack it real good prior to bolt removal.
JM2C
i had a suspicion the ubolt clamp force in itself was enough to slightly deform the tube. this likely explains why theres a ton of photos with flaking paint directly under the perch , before the trucks ever had a ounce of weight in the bed.
your statement of the OD being 1/8" more at 90* measuring locations confirms it even more
Himni, I didn't know that Stevie Wonder could weld!
Exactly! I only hauled our new washer and dryer and pulled our small (3,200#) camper a couple of times. All the deformation is from the U-bolts. Unfortunately the way Ford is instructing the dealer technician to inspect the axle doesn't show the deformation, so the only ones that are going to fail are the ones that are severely deformed. We probably won't see a real recall until a few welded ones fail completely and start leaking oil like the first couple did. I still have not taken mine in. It stays in the garage for winter. It's not my daily.
