Rear axle weld issue recall ?
"What is going to happen if the welds do not hold. The vehicle up to this point has not been used for heavy loads. The axle deforms. Is Ford going to do a second fix?"
They will if they know what's good for them. They'll wish they
made toothpicks once I sic my lawyers on 'em. Maybe you've
heard of them: Dewey, Cheatem, and Howe.
Presumably Dana has seen the light and addressed their QC issues.
My 350 6.7 is in for the recall. Dealer has done the inspection and confirmed my conclusion that an axle replacement is not necessary. However, they are having issues getting the parts (ubolts and associated hardware is one-time use and must be replaced as part of the service). They have had the truck for 10 days so far and can't even tell me an ETA for the parts. Their excuse is something related to how the parts are ordered due to a requirement from Ford.
So far I'm not impressed with Ford service. Never had these issues with other brands.
If your axle does not need to be replaced, why are they waiting on any parts. Isn't the weld "repair" performed with the axle in the truck?
Yes, but the U-bolts and other hardware are considered one-time use.
I stand corrected. When I originally researched this repair when it first came out, I thought they were just welding with everything in place. The videos out now show them unbolting the axles.
I'm still not getting it done. Another reason I ordered a 2022'....
I don't speak weld. But I work in pipeline where we have a bunch of guys who weld a lot. Can you please tell me more about why you say the weld would fail?
Many thanks...
I’ve been welding for 46 years. I wouldn’t be worried about those welds you got there. You can inspect them occasionally while your truck is still under warranty.
I agree. That weld looks fairly decent. It's way better than other general welds I've seen. For example, PTT on YouTube had a video of the axle repair. Now that weld was not pretty. It was done by someone with no welding experience and a garbage Amazon welding mask. Hopefully he won't go blind. But I guess my point is that the recall is probably being done by someone with little to no welding experience. That is of concern to me. I'd rather have it done by an expert or have the entire axle replaced. My biggest fear is having someone with no experience torching the axle and causing it to be less reliable than before the weld.
I took mine in to Super Ford in salt lake and inspected it after, they did a really good job and also replaced the U bolts and nuts with new. Said the axel was all good and showed no signs of needing replacement upon inspection and completed the recall work. It was a 2 day job as they had to take it somewhere to be done professionally. My recommendation is to utilize a major dealership for this.
Ok welding experts, how will they determine "At Risk" welds ..? And, arn't these Axles Assemblies supplied by Dana ..?
I took my 2021 in for this recall. The dealer uses a feel gage to check the gap between the axle and the support. If it is small enough of a gap (don't remember the number) they weld it, if the gap is too large the replace the rear axle. I waited for my service and it took around two hours.
i would run far away if youve got a recall axled truck. a youtuber cuts the tubes open and theyre a measly .188" wall. he measures a updated version at .287 or there abouts. still doesnt seem heavy duty in my book
The weld repair is a BAD idea! As previously posted by others, it will further weaken the axle and further deform the tube.
The repair is also calling for replacement of the U-bolts. This is to allow the area to be prepared for welding. They have to be removed in order to grind the paint off before welding. The installation and torquing of the new U-bolts will further deform (CRUSH) the axle tube. I measured mine (2021 F350 6.7 tremor) and found it to be out of round by .180"-.190". That is the measurement taken right next to the spring pad shows the axle to be crushed by over 1/8th of an inch!!
Welding and repeating the torque of the bolts will make this worse, not better!!
I also have the paint flaking off the deformed area around the spring pads as others have noted.
I am a machinist/engineer for the past ten years and turned wrenches for fun and work for twenty years before that.
I can tell you that the only way to fix this issue is a replacement axle with a tube wall thickness that is capable of the loads required for the bolt torque and all outside forces of payload and drive line torque.
I plan to bring all my findings to the dealer service and will update here as I can.
Thanks for all your posts and for reading mine.
Nate
After two weeks and still no parts in sight, I picked up the truck and told them to call me when the parts come in......
7.3 guys..........are you going to chase/fight this issue or not worry, drive the truck and hope for the best? taking votes!
I'm not worried. After all, we get reminded daily that we ain't got all that torque to make a difference.
Took mine in today. Visual and measurement shows no sign of deformation. “Ok, how long will the weld take?” Oh, we’ll have to schedule that at a later date…..it’s gonna take at least four weeks to get the U bolts etc. Has anyone taken theirs in for the recall inspection and needed a new tube?
The Tech who did my repair said he has seen a couple of deformed axles. My selling dealer said they had seen one or two but these were on trucks that were used in a construction environment. I wonder what it really takes to make these tubes split. If it's monster torque (which causes the axle tube to peel away from the spring seat), the weld would seem to do the job. If the tube just crushes under the weight of the truck/payload), then I think the weld might provide a little more support (sort of turns the spring seat into a reinforcing collar of sorts), but I am not sure how much.
I guess the question is how much the NHTSA (or whoever) looked into Ford Solution. Hopefully they are closer to Nasa then the carbon based blobs that have infested our local and state governments.
I'm not an ME but intuitively Ford's fix makes sense.
That said wouldn't it be nice if we as consumers were allowed to
know how many trucks had these suspect axles? It makes no sense that Ford requires a visual inspection. Surely every truck
within a time frame had the under-spec axle so WTF? If every one didn't then that raises more troubling questions of QC to me.
I'll bet you that if the 'fix' does work then Ford will start making
all axles lighter to save money.
There's a guy called Ford Boss Me on YouTube who has posted links to the documents which explain how many trucks are affected and when the weak axles were produced (something like August 2020 to May 2021).
Right but I think the question would be how many have deformed?
Visual inspection is like going to your PCP only to have them tell you, “yep you need a specialist “. Gee thanks. At the very least it’ll be a weld so if I’m taking it in for the recall why not have the parts on hand to fix the problem?
