Digger Thanks so much for the help..
My pleasure. I quickly gave up trying to get to the headlight plug and knew the much easier way was to go to the AUX switches. Super easy job and less than 30 mins from start to finish and there was zero swearing or bleedingDigger Thanks so much for the help..
If you didn’t bleed, was it a worth it? ???My pleasure. I quickly gave up trying to get to the headlight plug and knew the much easier way was to go to the AUX switches. Super easy job and less than 30 mins from start to finish and there was zero swearing or bleeding![]()
Could be a potential group buy?![]()
I'd be in. Been holding off until warmer weather as I don't like messing with plastic clips and trim pieces when it's below freezing.I tried a few months ago and never heard back. I'll try again!
Couldn't agree more. It was like 25 out when I did mine on Sunday morning and like I said I gave up without much of a fight with taking everything apart to get to the headlight plug and went to the AUX switches.I'd be in. Been holding off until warmer weather as I don't like messing with plastic clips and trim pieces when it's below freezing.
What did you ground to? I’m connecting to the aux switch also and that works for power but not sure on groundingCouldn't agree more. It was like 25 out when I did mine on Sunday morning and like I said I gave up without much of a fight with taking everything apart to get to the headlight plug and went to the AUX switches.
I went right to the battery for the best possible ground.What did you ground to? I’m connecting to the aux switch also and that works for power but not sure on grounding
Absolutely! I installed a set today and decided to tie into the up fitters, easy peasyCan they be wired into the upfitter switches if you have LED lights? I was considering getting them. They have a 3 light option and a 4 light option.
Agreed. One instruction sheet had me removing the wheel well protector and going up from there. Too hard, switch #4 now operational.My pleasure. I quickly gave up trying to get to the headlight plug and knew the much easier way was to go to the AUX switches. Super easy job and less than 30 mins from start to finish and there was zero swearing or bleeding![]()
Which lights are these? F150LED.com?I went to the AUX switches and it was a super easy install. 30 mins max.
You don't have to remove the whole liner. Just remove two 10mm bolts and two plastic push pins on the front of the liner and pull back. Reach up and unplug from back of light and splice the brown/yellow wire with included connector. I couldn't get my air box to remove so I went that route.Agreed. One instruction sheet had me removing the wheel well protector and going up from there. Too hard, switch #4 now operational.
