Raptor Style Grille Lights for Tremor
So if I read and see this right, one is a stick on type and the other is a predetermined spaced bracket that bolts on? Is this correct? I’m thinking of doing this and would probably spend a little more for a bolt mounted type than stick on. That’s just my thoughts!
Bolt on best ... this is Bambi mode by the way ....
Has anyone found a good in Grill plug and go LED light kit that use the uplift switches. I would rather have the option of being able to control when they are on/off, rather than use the headlight switch.
Thanks
An idea ?
Use this (5) light kit and install it at the top of the grill.
Then use this (4) light kit turn it upside down and install it at the bottom of the grill.
Thoughts?????????
An idea ?
Thoughts?????????
That is my thoughts when it is warmer. Custom auto works white kit for halogen lights and just run to an upfitter. I have to go lights off except for running lights when going on base. Would like to be able to turn the grill lights off independently.
Thanks
My picture above is using the upfitter switches
Digger29 Did that have a plug in to uplift switches or did you have to splice in?​
You have to splice into the brown and green wire which is AUX switch #1. There's a bundle of wires taped off under the fuse box on the battery side. There's a great 10 min video on YouTube showing you where and what to do.
Trust me its much easier to go that route than splicing into your headlight wiring.
I had this work done by my Race Shop .. they told me that the upfitter switches are a "genius" option and very easy to address... I have the raptor-style lighting on one and additional yellow fog lights on another.
Anyone with the factory LEDs, how hard is it to get to the wiring and do the splice?
It’s not very hard. 1st remove the push clip in the photo and pull out that airbox port. 2nd unclip airbox lid and remove the filter and lid. 3rd remove airbox base by removing one bolt between base and grille, then turn the large base nut (at bottom of base where filter sits) to loosen it. The base nut does not come out, it just spins 1/4 or 1/2 turn to release it. 4th reach under the remaining piece of airbox to pull out wire loom and use a razor blade (carefully) to remove a section of electrical tape. You can then pull the headlight wires out of the wire loom and tie into the hot wire you want and ground to battery or frame. I am 6’4” tall and still needed a small step ladder to reach the wires.
