With the LEDs, you have a few options - get the adaptor and attach to the running lights, wire to a switched upfitter so you can control, or wire to the constant wire that is found in the upfitter bundle.Sweet, Thank you. I have LED's and I may opt to add them to an upfitter for the easy install. No need for the plug an play option, I'll save the $30 for other mods!
I chose to wire mine to switch #1 so that I can shut them off if needed. I figure if I run out of upfitter switches, I will move it to the constant wire.
Erik
