Pickup Box Bed Side Storage (19H)
Unfortunately I gotta remove these from my possible wants list. My Pelican case still has more total Ft³ of storage and can be taken out pretty quickly.
On another idea, It would be slick to utilize the dead space in between the bed skins for hidden auxiliary 'saddle' fuel tanks. Darnit, something else I have to play with now 😂
When I first got my truck I was thinking about a couple of these but I don't think it would allow 48" clearance between them. I also didn't think the height would work with my tonneau and they aren't really "integrated" into the truck.
I like the bed skin idea, though!! Could be a great use of available space.
Now I'm curious what the volume of fuel would be to occupy all that 'dead' space 😮
Driver side could be fuel, passenger side tank could be water for camping.
Didn't you just purchase half of a bed? Seems like a good use for a prototype. ;)
Did, but left it there for them to scrap after I harvested the piece on site. Didn't have the energy to load and unload it.
Hey now! I've taken down a few big trees with a sawzall! Don't underestimate the sawzall! 🤣
Hmm. What’s the biggest blade someone has fit to a Sawzall? Think we could get a 36” blade on there?
Working around the tree that could be a 6’ diameter tree one could take down!
Hey everyone, I think I discovered a really cool 'hidden' feature of the side box storage no one has found or talked about! Looks like you can use it as a bed divider by putting at least a 2x6, or 2x8 in these slots.
Would appreciate if someone can confirm this, and also the largest 2 by lumber size that will work. @GadgetB1 @HelmPilot
You are correct! Here you go, I suspect you can run taller boards if you cut out either an angle or notch out for the lid being open.
This is awesome! Surprised Ford or the manufacturer doesn’t talk about this feature. I may reconsider these then :)
It looks like a 2x8 would be the biggest that would fit without notching the board (for when lid is open). If anyone has them installed on their truck, can you try a 2x8 out please?
I think I could make this work by consolidating gear, moving the Maxtrax recovery boards and shovel to a BuiltRight bulkhead panel, and swapping out my M18 Fuel chainsaw for the M18 Fuel hatchet.
I've kicked around the idea of putting an air tank up in there.
Fuel/water storage is a great idea tho. Just tell me when your site has an email signup ;)
I like this but not for that price tag:cautious:
The tether cable is pretty pointless, and my assumption is it's purely only for highway safety reasons, should the bolts ever loosen up, it will prevent the storage box from flying out of the bed if the vehicle gets in a wreck.
That seems to be the only use for them. Chances are in a high impact wreck or rollover the boxes loaded heavy would tear the cable mount out of the fasteners came loose .
Indeed. If I get these boxes, I probably won't install the tethers.
