Pickup Box Bed Side Storage (19H)
That seems to be the only use for them. Chances are in a high impact wreck or rollover the boxes loaded heavy would tear the cable mount out of the fasteners came loose .
Anything that is a "Genuine" Ford Accessory has some crazy hoops to jump through to get that title. I imagine that's one of them.
A "Licensed" Ford Accessory on the other hand, isn't much more than Ford branding on an existing product.
According to the Ford site, these are genuine accessories
I’d really love to know some dimensions on an 8’ bed version. I really like the idea of straps and hitch storage in the box without getting in the way of floor space. Would be nice for sleeping in the back when I put my hi-rise canopy on.
From the build site, looks like they're the same as they stop short.
  • Useful
Reactions: ccw
Thank you sir. Somehow I missed this picture. Too bad it’s the same box and not larger but understand for manufacturing purposes.
So, found them on the Ford accessory site. Different part numbers, but up to storage area is the same.
Lol thanks! Without the wrap around handle I think so. Here are some measurements of the opening.
Thanks for those pictures. You wouldn’t happen to have a 50 cal metal ammo box that you could check fitment for me? I usually keep straps, recovery shackles, portable air compressor in those ammo boxes and would be really neat if they fit and even stacked 2 high.
Thanks in advance
Edit.
The 50 cal ammo cans fit perfectly in the underseat storage compartment, although they have to be on their side which is a bit inconvenient. It’s easy to swap boxes depending on use or to grab one box to put in another truck.
man i like this, as I use my swing box a lot but I dont think I can give up my cleats.
Thanks in advance
Edit.
Sorry I am a poor and don't own any 50 cal ammo cans but, I did find a box a bit smaller that is roughly the same depth and height. Spoiler it doesn't fit...
It looks like a 2x8 would be the biggest that would fit without notching the board (for when lid is open). If anyone has them installed on their truck, can you try a 2x8 out please?
I think I could make this work by consolidating gear, moving the Maxtrax recovery boards and shovel to a BuiltRight bulkhead panel, and swapping out my M18 Fuel chainsaw for the M18 Fuel hatchet
This 2x6 is cut to 50 1/4" - a 2x8 would work if you cut a two-inch taper on the top corners
Thank you for doing this! Looks awesome and as expected! Ford would sell more of these mentioning all of these features.
Is this your truck? Looks identical to the other red truck the manufacturer used to post photos with the OSB plywood.
No, my buddy works at a dealership and they have been testing these things out with trucks on the lot so I asked him to look into this.
Anybody have the weight of the empty storage box? There’s a ‘100 lb’ shown in the instruction sheet, but that may just be the load capacity. Trying to get an idea of how much less or more weight I’d have compared to the Pelican box.
Got a quote on these boxes beginning of June. Went into ford yesterday to pick up oil and filter for an oil change and spoke to the parts counter about these boxes. They said the price increased by over $400 from when I first got the quote… so I ordered them right then as they would honour the original quote. Looking forward to them coming in.
Update: manufacturer told me each box weighs about 15 lbs, so the 100 lbs would indicate the load rating for the box.
I scored (tomorrow hopefully) a set of these for $200 on marketplace for some factory seconds someone had buyers remorse on. Missing the tethers and some bolts (don't need the tethers anyways). Plan on picking them up tomorrow at Cabela's for a cash deal. Hopefully not a scam and will post back!
Wow, that's a great find if it pans out. 🤞
Picked the boxes up and installed them after gathering up hardware at some Ford dealers. Additionally, cut a 2x8 divider (which will be painted black).
It's definitely a Tetris game trying to fit everything I want into these. I have a few more things I need to figure out how to wrangle into these.
