To answer my own question, the Side Bed Storage Boxes will work with a Leer HF650M Tonneau Cover, and with a Bedrug Classic bed liner. But I'm not sure about the Bed Extender (and debating whether to even try -- just eyeballing it I don't think there's enough room).
For some reason the box on the driver's side was a lot easier to install than the box on the passenger side. In both cases some pressure (weight) had to be put on the boxes to get them to depress (or seat) sufficiently into the Bedrug liner so that the mounting bolts would thread correctly, but I actually had to use some dead weights in the passenger box (about 70 lbs) and let it sit for a few minutes so the box would settle/compress the Bedrug sufficiently for the mounting bolts to thread correctly into the mounting brackets.
And, as I believe someone else already mentioned, the boxes will not open or close unless the tonneau cover is fully opened (retracted). Plus, the bracket for the tonneau cover's safety strap on the passenger side had to be rotated 90 deg so the box wouldn't hit it.
But, even with these caveats I"m still happy with the result. My F-350 has the 2K Pro Power option (which displaces pretty much all of the normal rear under seat storage) -- so having somewhere else to keep hitch/recovery/towing stuff is very helpful.
FWIW -- If there's a next time (to buy another tow vehicle)... I'll almost certainly get the spray-in bed liner and then add the Bedrug mat. Installing the Bedrug classic liner is too much work!
