Front axle diff locker upgrade
Weren't you the one who had issues with your Eaton locker? So, that is a con for me, with limited warranty help and parts availability from Eaton based on YouTube comments.
ARB has had leaking issues.
The locker ended up not being the issue. There is nothing wrong with Eaton at all.
The issue was a domino effect of overextended stock brake lines (pinched lines) in off camber situations locking up my tires from wheel spin (front), dragging them while in gear and in movement.
Stainless stell braided brake line extenders were added and the issue was quickly resolved.
I am running my ICON lift (4.5") without limiting straps.
ARB. A bit late to the conversation. Ran ARB in my two Jeeps and loved them.
My jeeps also have ARB's front and rear and wouldn't run anything else. If they leak it's nearly always an installation issue.
And if anybody needs a compressor for them I highly recommend getting one of these even if you have an additional onboard air system.
What’s the benefit of that if you have already have onboard air from a larger compressor?
@Vecman Let me know how your front E-locker install and review goes and I will consider it.
Will do. They’re ordering the parts now. Assuming no issue getting it, then I’ll drop the truck off for install in early August. Gonna have them install the trophy hitch as well at the same time.
SDHQ called me today, and said the Eaton rep told him that they do not have a confirmed front locker for the 2020+ superduty trucks. Meaning, they’ve seen a lot of differences in front differential sizing that they didn’t yet have a product they could confirm fitment for. Now, that doesn’t mean they don’t have one that will work, it just meant that there’s not an approved part for the certain year truck due to these variances. Weird in my mind. So, that being said, has anyone on here installed an Eaton E-locker on the front axle in a 2022 tremor? I want to get this done, but I need to know the right part that will fit before i spend the money. SDHQ has no issue installing it, but since the rep didn’t help them, and they don’t show a part # to order, I’m at a standstill
I have the eaton electric locker on the front axle of a '22 MY Tremor.
Nate from Arizona Differential in Phoenix (602) 272-4600) did the install - get a hold of him and ask him about my Red Tremor, I'm sure he'll remember as I was in there not too long ago getting some other items done.
It was also wired it up my switch pro SP-9100.
I thought I remembered you having this. Thanks man!
Dropping her off tomorrow morning. Appreciate the referral!
Chalk one for Nate, he's a great guy and so easy to work with.
Once you loose profound love for that Headquater place, you'll find reasons not to need to go back.
I locked her in today going up some wimpy yet loose and uneven climbs while out on a survey job. The first attempt was to notice a difference while in 2H, started quickly loosing grip and caught some wheel spin, put an end to that. For the second attempt, locked her all in, front and rear (totally unnecessary), crawled up like nobody's business.
I'll be down in your neck of the woods tomorrow (Queen Creek) working.
Well, got a call a few days after dropping her off that Eaton locker is backordered and isn’t anticipated to be available for the rest of the year. That sucks. Sure wish they would have let me know that before I dropped her off. Good thing is I got the part number so I know what will fit. Now I just have to wait till whenever
Bummer bummer.
I had been on the front locker topic from when I took delivery of the truck in September of '21 and finally when Eaton released (or confirmed fitmen from the help of Nate) we jumped all over it and got it put in.
Must be a hot commodity or not many go into production.
I would keep insisting; sometimes these production companies don't even know what they have or when they will recieve inventory.
Can you confirm this is the Eaton part #? 14022-010
It's what I found in my research for the front locker.
That’s the part number they told me would work, and what they installed in @AZsurveyor ‘s truck
