Front axle diff locker upgrade
Not to be argumentative but it does disengage when reversing. It locks based on a ball-ramp design. There has to be a slight rotation to drive the locking mechanism ball up the ramp when going from forward to reverse. At least on an Eaton e-locker. Filthy motor sports has a good explanation of this on YouTube. Again not being argumentative but
Yes, for that style you are correct (ramp/ball actuation). The ones for the Dana 60 are direct acting pin style that do NOT disengage when switching directions.
I can’t see a reason to “upgrade” the rear. There are very few of any stories out there of the locker itself failing, and it has been around quite some time. However I can see the need for a speed limiter override. It doesn’t seem that it would be hard to do, but I have to put any time into it. 20 mph is a pain in the rear when needing both tires spinning, but still trying to clean out the treads.
I was taking it that the poster was asking so that they could review a comparable front unit not necessarily upgrade the rear. Just my interpretation though...
You can also use the brake pedal to help that front diff. It will help you through more than you might expect.
There aren't many places I'm willing to take my huge expensive super duty where I truly need a front locker. That said, if I had one, I'd find a way to need it.
Ah I see, Eaton updated this to the Elocker 4 which uses an armature to engage mesh gear against the spider gear on the right side of the case now. That’s cool and hopefully will make for an even more reliable diff lock.
Been a while since I looked at these so I was out of date on my info
Just going to throw this out there as another option. The PowrLok limited slip can be set up as aggressive or tame as you wish. On the tame end it'll be just like what we have stock now. On the other end, it's almost (not quite) as aggressive as a locker. Set up that aggressive, the clutches will wear more quickly, but you won't be playing with the brakes either. No engagement switches, air, electric or mechanical to mess with
Interesting, wonder what they cost?
I'm going to throw this link here for information only. In it is described different differentials used by Dana/Spicer. They describe the Trac-lok that we have as a limited slip designed to "complement brake based traction control systems". This is why using the brake helps it work.
I decided to go with an front electric locker.
When I need full front traction, I don't want to be bothered with braking and fooling the clutch pack to alternate back and forth for traction. I am not trailing running for fun; I am using my rig for work purposes and at the end of the day, I need to get the job done and back home.
I thank Ford for giving us a front LS but for a Tremor, if intended to compete with the Power Wagon, should have came with both front and rear lockers. At least, start offering this option to the buyer.
IIRC, the F150 Tremor does-
Which unit did you go with? and if you had it installed mind if I ask how much for installation? Thinking about doing the same thing.
