I saw was I kept reading lolLol, I mentioned that above![]()
valid point, ok so how does an arb air locker blow axle seals if the air line/locker fail? I’ve never owned an arb locker I’ve just read this on various forums over the years.Axles are vented. Shouldn’t be air tight.
I get it you read it on the internet it must be true...valid point, ok so how does an arb air locker blow axle seals if the air line/locker fail? I’ve never owned an arb locker I’ve just read this on various forums over the years.
Have you tried pulling the hubs and going for a drive?I've been having a lot of problems with my differential. My dealer just replaced both half shafts and bearings which helped considerably, but it's still making rotational/popping/grinding sounds when I'm turning. It's like the Hubs arnt unlocking and the L/S is trying to engage. I realize it's under warranty, but I have a set of Warn Hubs on order. If they don't solve the problem, I guess I'll be in the market for an upgrade myself.
Once energized and engaged, it will not disengage unless you shut it off, or the wires get cut. So no engage/disengage from forward to reverse. And the engagement method (splined hub mechanism that engages with one of the spider gears) is the same method that ARB lockers use.Eaton E-locker part number for 4.30 gear axle in case anyone wants it : Q14022-010
Edit: also the eaton needs to turn about 1/4 turn in order to engage which to most folks won't be noticeable but should be considered if you are trying to "rock" the truck while stuck in mud. Could be hard on the diff as it engages and disengages between forward and revers. I've never heard of a failure of the actual locker components themselves but that's anecdotal.
GF
Not yet, but I plan too ..Have you tried pulling the hubs and going for a drive?
It's probably 7-8 hour job plus oil, rtv/gasket for diff cover, plus running switch wire....I would ballpark it at $1500-$2000. Full disclosure never installed on a dana 60, most of my experience is with 30/35sWhat would labor run to install a Eaton locker?
After have a Jeep with lockers I like the idea of having front and rear. Highly doubt I would ever need it though.
I think I see a goldfish in there.
Not to be argumentative but it does disengage when reversing. It locks based on a ball-ramp design. There has to be a slight rotation to drive the locking mechanism ball up the ramp when going from forward to reverse. At least on an Eaton e-locker. Filthy motor sports has a good explanation of this on YouTube. Again not being argumentative butOnce energized and engaged, it will not disengage unless you shut it off, or the wires get cut. So no engage/disengage from forward to reverse. And the engagement method (splined hub mechanism that engages with one of the spider gears) is the same method that ARB lockers use.
Ok I don’t need it that bad lolIt's probably 7-8 hour job plus oil, rtv/gasket for diff cover, plus running switch wire....I would ballpark it at $1500-$2000. Full disclosure never installed on a dana 60, most of my experience is with 30/35s
You aren't missing much. By the time I finish my build, the only 'Tremor' left will be the bed sticker, rims, and the rock crawl mode.Watching this with great interest since I am a non-Tremor and would like the added capability... Kicking myself now for not checking the Tremor box on the order form.
Weld the diff and switch to manual locking hubs. You can choose 2, 3, or 4 wheel drive whenever needed for like $300.Ok I don’t need it that bad lol
That's a great point, plus eliminates the vacuum hub system which can be plagued with issues.Weld the diff and switch to manual locking hubs. You can choose 2, 3, or 4 wheel drive whenever needed for like $300.
Out of curiosity, what does Ford use for the rear locker? and would you upgrade the rear to match the front?
